1 members (JoeSpeetjens), 328 guests, and 38 robots.
+8Rich 94
Posts837,276
Thread Like Summary
JohnHarris, MartO, Plus Four Guy
Total Likes: 5
#836164 01/01/2026 12:16 PM
by MartO
MartO
Hi again and Happy New Year,
I'm still working my way through my little list on the Plus Six I bought last month. I would welcome further advice please.
With the hood up, the driver's side is a relatively draught and noise free. However, the passenger side is noisy. In her 1st trip, my wife found it very draughty from the top of the sidescreen where it meets the hood. Investigating on that side, I have a gap between the top of the sidescreen and the hood. It seems the sealing flap of the hood (the area above the fixed side window) is too far outside the cabin to rest against the outer top of the sidescreen. I can see daylight there from inside the cabin and can easily get my fingers between the top of the sidescreen and the hood. This isn't the case on the driver's side.
I don't think there is any adjustment in the sidescreen available. Ideally, if that could angle outwards by 3/4", it would then nicely snug up to the hood flap. But that would change the fit at the A-post and there is a just sufficient fit along that front seam of the sidescreen to A-post. I don't want to mess that up. Possibly, looking at the top corner of the sidescreen and A-post fit, there is room for the sidescreen to sit higher on the door, by about 1/4", before it gets too close to the A-post capping. Not sure how I could raise the sidescreen, nor whether that will harm the fit of the sidescreen to the rest of the door. But I doubt lifting it would improve the gap to the hood.
So, I'm currently thinking any adjustments will need to be to the hood. Perhaps, my hood might be a little too wide at the top?
Has anyone come across similar and found a way to adjust it?
Another little niggle is the sliding windows on both sidescreens. After a few minutes driving, they seem to open very slightly, needing to be closed shut. Only 1/4", but it introduces noise/draught. I'd like to fix it. Again, any suggestions please?
Edited: to correct the inside / outside references!
Thank you, Martin
Liked Replies
#837815 Feb 2nd a 12:34 PM
by MartO
MartO
Photos of the seals added to the passenger side.
The first is the D seal added to the front of the soft top frame, above the factory seal:
Next the new seal is on the inside of the rear edge of the sidescreen:
Next photo is the rear of the door below the sidescreen, showing seals on the bottom fabric area of the sidescreen and the door panel. There was already a flat closed cell foam seal by the door catch. I don't know if that's standard, or added by Krazy Horse:
Finally, the seals on the front area of the door and on the sidescreen:
The driver's side wasn't as bad. It has some of the same seals on the rear of the door, only one on the front and nothing needed on the hood frame.
Hope the photos upload OK for you. Sorry the orientation is wrong on some of them. They are also in the photos section somewhere on the forum!
2 members like this
#837563 Jan 29th a 07:33 AM
by TeddyAds
TeddyAds
The water collects in the inside corner of the screen on the driver’s side before dripping onto my leg but I can’t see where it’s getting in. I’ve since discovered how to open a new thread and received a couple of kind responses, both suggesting applying silicone. I’ve also come across an earlier thread with photos showing where to apply the silicone so I’m pleased that I asked for guidance.
1 member likes this
#837579 Jan 29th a 04:23 PM
by John V6
Sealant under the bosses and grease on the safts
1 member likes this
#837819 Feb 2nd a 12:54 PM
by DaveW
Its good to see someone taking up the baton of using neoprene seals on the CX cars! grin2
1 member likes this
