6 members (esse16, Ritchie B, Bitsobrits, Tony Quinn, IcePack, Rog G), 285 guests, and 107 robots.
+8Rich 77
Topics49,868
Posts837,642
Moggo
Thread Like Summary
+8Rich, BertL, gomog, Graham, G4FUJ, Mick Annick
Total Likes: 9
by Calypso Red
Calypso Red
Hi everyone, especially those who collect part numbers!
I'm going to change the engine oil on my 1994 +8, 3.9lit. The council of perfection requires me to replace the copper washer on the drain plug. (Or is it OCD?) I would like to have a new one to hand so I don't have to end up packing the oil pump with vaseline. Does anyone happen to know a part number for the copper washer?
Rimmer Bros. list various ones for V8's with id. of 14 or 16mm. I have a used one which might be from a previous oil change but is poorly labelled and is 20mm. Also, any preference for domed or flat washers. Any ideas please?
Regards
Liked Replies
by Ian Wegg
Ian Wegg
Originally Posted by Calypso Red
Copy and paste!
.. or just click: www.ebay.co.uk/itm/293657793939
I know I bang on about this every time, but I will again! The URL ends at the "?", everything after it is data being passed to the website. Not only can you omit it, but you actually should do if you're sharing it. There is information in that string that you might not want visible on a public forum.
2 members like this
by sewin
sewin
Yep, Lorne has told a lot of truths, The assortment boxes are great, everyone should have one as they have a multitude of uses but unfortunately they generally don't go to large enough sizes for most sump plugs or fillers.
Crush washers are as shown by gomog here and are designed to form a seal so are the best choice if that's what is needed. Most post mid eighties cars tend to have better threaded sumps and plugs so don't tend to leak that much as they also include flanged bolt heads and machined seats. Think back( those of you who like me are old enough) and you will remember most sump plugs had small weeps even if providing a fairly good seal and often needed a sealing compound or tape as they aged. plain copper washers work fairly well but really need annealing first. If using PTFE tape or a compound like hylomar blue don't be tempted to cover to the end of the threaded portion of the plug as you do not want any of the residue to enter the engine. and when you remove the plug inspect the threaded hole in the sump to make sure all previous solutions have been cleaned away before refitting the plug. Incidentally Hylomar blue is a non setting sealing compound in that it goes off but stays soft.
Now let's look again at the aluminium sort. They really are designed to be used only once as they tear. They work in a different way in that as you tighten the plug the washer deforms into the bolt and tightly fills the void at the top as it's displaced into the shaped head of the bolt shaft and it is this action that forms the main sealing effect. So the torque setting is a prescribed force to achieve this action and no more. When removed the alloy washer should be tightly attached to the plug. Now here is the rub, If the face is smooth and intact its possible to to use it again and you'll know this if the car spec gives a range for the setting torque, say 23 to 28 ft lb, then you would use the lower set.
The manufacturer would however tell you to always change the seal! But not their shop mechanics who seem able to assess ye or nay. This only works if you do not attempt to remove the washer from the plug. While we are talking about sumps and oil, if you have the spin on cartridge type, tin can type, when you have loosened it a couple of turns get a screwdriver and puncture a hole centrally in the bottom of the can, they're not very thick. I have an old screwdriver with a shaft of about 1/4" which I have sharpened to a point. This works well but for years I used an old Phillips
, the round shaft of the screwdriver doesn't leak oil out until you pull it clear! Let it drain now and when it stops you can undo the filter fully without getting an arm full!
Points of note;
Be assured you have the correct replacement filter as there's no going back!
And again on fitting the new one, lubricate the rubber seal with oil and hand tighten only. How tight is tight enough? Well you will feel it start to tighten by degree until it stops, then grip it as tight as you can and try and tighten it further. You'll find it will tighten a little more but not much..... now walk away, no need to touch it again just a visual check for leaks on first start and short running time.
2 members like this
by RichardV6
Suggest buying a box of various sizes. Always useful to have around when need arises.
1 member likes this
by Image
Have a box of these on the shelf.
One thing to note is that, because I have a bunch of old vehicles, I bought a box of imperial washers off a well known auction site ... to find they were just metric ones re-labled to their nearest imperial equivalent. 😡 ... had to re-buy from a proper supplier.
1 member likes this
by +8Rich
Mike - I feel the need to invest now - thanks for the link smile
1 member likes this
by +8Rich
Originally Posted by +8Rich
innocent
Now you know why he is on ignore with me laugh2
And no, I haven't read the post.
Yes you are right rofl
With the exception of No2 Daughter anyone legal can drone on for hours about nothing - it's attrition they think they will bore the arse off you in court and you'll agree.
As we see on here it doesn't work that way as there is far too many knowledgable people to shut him down or ignore him so his posts become historical chewing gum..
He does have a few loyal followers it would appear.....good luck to them both....
1 member likes this
by Calypso Red
Calypso Red
Who would have thought copper crush washers could be so interesting!
The aluminium 14.5mm ID ALU1403L washer is probably best used with an aluminium sump if you have concerns about galvanic corrosion.
The 16mm ID 213961 washer seems to be used for the 3.5lit Rover V8. You can also use 213961L or 213961A which is labeled a crush washer. These are all the same size and, not surprisingly, all look the same. However, they can also be 20/21mm ID!
Then we have ETC 7398 which is also 20/21 mm ID and seems to be associated with the petrol injection 3.9lit engines.
Confused? As far as part numbers are concerned it's a bit of a mess.
I think the answer is to make sure you have the same ID washer to hand as the one you took off, whatever the part number.
On the other hand RichardV6 probably has the best idea of buying a selection box.
To be on the safe side I've bought two ETC 7398 and a selection box. This should last me well past the time when I've forgotten I even owned a car! farmer
1 member likes this
