3 members (Topline123, TalkMorgan, Image), 263 guests, and 50 robots.
Posts837,252
Thread Like Summary
Paul F
Total Likes: 1
#844029 05/28/2026 10:57 AM
by AndyMog57
AndyMog57
Afternoon all.
I have a CX with wire wheels, hence splined output shafts. I have to regularly remove the rear wheels to relubricate the drive shafts with graphite grease to prevent drive shaft knocking (seriously irritating). I currently use Castrol graphite grease.
Over the last four years I have noticed the problem rears its ugly head after driving in very hot weather. After a return trip to Malvern on Tuesday when I saw a temperature of 33.5C, the drive shafts started knocking on the way home.
It suggests the grease is thinning due to high ambient temperatures.
Is any one aware of, or using, a high temperature alternative graphite grease that holds out longer and hence requires less attention?
Cheers, Andrew
Liked Replies
by AndyMog57
AndyMog57
Originally Posted by Paul F
Originally Posted by AndyMog57
What I do know now (oh, how I love hindsight) is that I would never again specify spoked wheels. Look good they might but they are far too maintenance intensive for any car.
Agreed. Having had two cars with wire wheels, they never even made the “possibly” list when we specified our Plus Four.
Given the way in which wire wheels are fitted to a Plus Four, converting to alloy wheels may be straightforward. Two questions would need to be answered:
1) Are the wings exactly the same width for the 2 options (wire / alloy)?
2) If you remove the wire wheel adaptors, are you left with a hub to which an alloy wheel can just be bolted?
If both are yes, then a specialist alloy wheel firm will be able to advise re dimensions and help you choose some good looking alloys. Wheel Mania in Hinckley are one option (as per the Mat Armstrong videos).
As to cost - no idea!!
Hi Paul. I took a look at Wheel Mania’s web site and Morgan are not listed. I will call them and have a chat. Not see Matt Armstrong’s video’s yet but will look up. I think that a conversion to alloy wheels is the only sensible solution, albeit yet another large Morgan related expense.
1 member likes this
