0 members (),
347
86
Topics49,873
Posts837,706
Definitely Old School Learner Plates Off!
Re: Stranded on the M25 in my 2006 roadster
The reason for the M25 breakdown is now very clear. Water in the actual pump connector. The attached photos show the culprit. So the current dilemma is ---yes we have a Ford replacement fuel pump BUT not the connector unless I want to buy the complete loom  ----any ideas apart from ebay. The garage say that if I can get the actual connector they can rewire it.
Posts: 28,904 Likes: 352
Posts: 28,904 Likes: 352 |
Try the Autoe electrical suppliers: e.g. Vehicle Wiring Products (VWP); Auto Electrical Supplies (AES) etc. They must be available if Morgan have used them...
Posts: 481 |
Thanks Graham----you must have Talkmorgan on a 24 hour drip! ---such a speedy reply---good job
David of SW19
 Not exactly, you caught me at the end of what should have been a lunch break, just returned from a delivery/collection run... Good luck with finding the necessary connectors
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
AES would get my vote. Any 6 pin connector should work (with suitable capacity).....
Richard 1976 4/4 4 Seater
Posts: 4,896 |
I would be tempted to re-wire it with soldered brass bullet connectors which should be a bit more resilient to water failure.
Adrian
Posts: 1,155 Likes: 2
Posts: 1,155 Likes: 2 |
Try the local breakers yard will be loads of fords in there ,cut off the connector you need and splice it in should will cost nothing.
Posts: 481 |
Yes the breakers route was suggested already by a very kind chap on ebay who also made the alarming comment that it was not a very clever failing for wiring attached to a petrol tank!!!
David of SW19
Posts: 8,015 Likes: 1
Posts: 8,015 Likes: 1 |
Nip into W H Smiths and pick up a Ford mag loads of places to contact. + they come in handy in the future.
Posts: 481 |
Great idea thanks!
David of SW19
