3 members (JohnHarris, Plus Four Guy, Graham, G4FUJ), 420 guests, and 107 robots.
+8Rich 76
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,873
Posts837,708
3 Images
Definitely Old School
Re: Stranded on the M25 in my 2006 roadster
The reason for the M25 breakdown is now very clear. Water in the actual pump connector. The attached photos show the culprit.
So the current dilemma is ---yes we have a Ford replacement fuel pump BUT not the connector unless I want to buy the complete loom frown ----any ideas apart from ebay. The garage say that if I can get the actual connector they can rewire it.
9 Comments
Try the Autoe electrical suppliers:
e.g. Vehicle Wiring Products (VWP); Auto Electrical Supplies (AES) etc.
They must be available if Morgan have used them...
Thanks Graham----you must have Talkmorgan on a 24 hour drip! ---such a speedy reply---good job smile
David of SW19
laugh2
Not exactly, you caught me at the end of what should have been a lunch break, just returned from a delivery/collection run...
Good luck with finding the necessary connectors smile
AES would get my vote. Any 6 pin connector should work (with suitable capacity).....
Drive on the Wild Side
I would be tempted to re-wire it with soldered brass bullet connectors which should be a bit more resilient to water failure.
Adrian
Try the local breakers yard will be loads of fords in there ,cut off the connector you need and splice it in should will cost nothing.
Peter.
Aero plus8 50th Anniversary.
Yes the breakers route was suggested already by a very kind chap on ebay who also made the alarming comment that it was not a very clever failing for wiring attached to a petrol tank!!!
David of SW19
Posting Desperado
Posting Desperado
Nip into W H Smiths and pick up a Ford mag loads of places to contact. + they come in handy in the future.
Great idea thanks! smile
David of SW19
