0 members (), 309 guests, and 27 robots.
+8Rich 86
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,360
Page 3 of 4 1 2 3 4
#350727 26/03/16 02:34 PM
alanhug Offline OP
Borghi Dash 2/2
two of 2
32 Comments
alanhug #351104 27/03/16 06:35 PM
That does look good
Peter J #351106 27/03/16 06:39 PM
Originally Posted By Peter J
My only concern is the passenger airbag door, it seems to have hinges along the lower edge. On the +8 the passenger airbag cover is designed to drop away below the dash, held by 3 seatbelt webbing straps. Has anyone tested the hinge mechanism works and doesn't foul the opening bag?
My understanding is that the veneered cover is made as lightweight as possible and will flip down out of the way. It is held in place with some spots of silicon that will not inhibit the deployment in case of need.
Actually testing it would be an expensive proposition I suspect.
Formerly known as Aldermog
Interesting: the air bag cover is not the MMC original part?
If it is held with spots of silicone (good idea) then why the hinges? Much better to have the thin cover just blow away.
Yes, testing properly is expensive, even if successful it destroys the car.....
MMC used up 11 cars crash testing the Aero chassis and airbags. It is rumoured that at the time they (CM) thought that they would be making 500 or so Aeros a year, with half going to the USA. So perhaps it made sense...in a CM Man Maths way.
alanhug #351310 28/03/16 01:50 PM
Keep it hinged - you do not want a hard cover flying and hitting you - trust me on that one.
Mark - No Longer driving
alanhug #351311 28/03/16 01:52 PM
It's a huge shame that MMC don't offer de-luxe bespoke dashes as an option. There's a market out there.
DaveW #351319 28/03/16 02:20 PM
Lets raise it at the next focus group.
Martin (Deano)
alanhug #351327 28/03/16 03:13 PM
A good idea...........and it was discussed as part of the Trad focus group.
alanhug #351400 28/03/16 08:15 PM
They probably don't due to homoligation issues.
Peter J #351409 28/03/16 09:02 PM
I'm pretty sure that the original cover is still underneath. You need to be pretty sure of what you are doing when you start to touch any of that stuff.
They seem to be able to fit things like MotoLita steering wheels that are not homologated on the car. Technically speaking these are aftermarket items fitted by Aero Racing. At least that was the case on our car.
Jays #351480 29/03/16 11:20 AM
I see no reason why they cannot fit an Aero 8 style dash to the Plus 8. The Aero 8 dash is homologated. All that is needed is some small changes to make it fit. The top wood edge could be replaced with a block of hard neoprene foam covered in leather.
I, and others, want instruments in front of the driver and the airbag door finished in something other than black plastic.
The Aero 8 achieves this. Finished in wood veneer with the switch panel in turned aluminium it would look simply stunning.
Page 3 of 4 1 2 3 4
