Topics49,849
Posts837,425
Misting Gauge
I've never driven a Morgan before and I was quite surpised to see misting in two out of three gauges. However this seems to be a known issue: Maintenance and Servicing: Workshop note - Misting gauges Is this a common issue or a rather rare occurrence?
Posts: 1,118 |
Correct it's aMorgan sir they all do that!
RogT Old Git Racer ex 4/4 sand 2013 +4 GDI Royal Ivory 2015 Ford Fiesta ST2
Posts: 12,257 Likes: 317
Posts: 12,257 Likes: 317 |
It's very common. so much so that if one's instruments don't mist up it's a cause for comment.
The causes and possible solutions have been discussed for generations, but no-one so far has come up with a definitive explanation (beyond the obvious, which is that there's warm moisture laden air inside the instruments which is being cooled to its dew point by the cold air in the upper part of the cockpit).
DaveW is currently drilling holes in his instruments in a strategy to promote better air flow. I've put in LED bulbs in an attempt to reduce the temperature inside the instruments. Others are toying with alternative solutions like wiring in additional fans.
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
The smaller gauges are worse than the larger ones. My large ones only mist in extremely cold weather when the roof is down. The fuel gauge seems to generate the most heat/condensation.
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
It's also worth knowing that this isn't just a Morgan thing
A quick search on the internet reveals that just about every classic car forum where the vehicles tend to be open cockpits have similar posts.
the ingredients are:
open cockpits glass fronted instruments (hence why modern polycarb intrument fronts in open cars dont do this) weather- very cold mornings and then driving in warmer conditions
There are two really good things about this happening: 1. You are alive; 2. you are driving your Morgan
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
The gauges on my 4/4 have always misted. It's never been an issue for me, as my spectacles also mist up.
Posts: 12 |
Thanks to all for your feedback on this topic. I'm delighted to hear to own the real thing and not a real lemon instead!
_________________________ Nick Burns 4/4 Two Tone Green 80th #68
Posts: 5,465 Likes: 171
Posts: 5,465 Likes: 171 |
If you were to find one of the rare ones where the gauges don't mist up and it doesn't let any water in when in heavy rain then you must have the Morgan equivalent of a Friday afternoon car. Some of the better dealers will manage this under warranty for you.
Posts: 3,695 Likes: 131
Posts: 3,695 Likes: 131 |
If you were to find one of the rare ones where the gauges don't mist up and it doesn't let any water in when in heavy rain then you must have the Morgan equivalent of a Friday afternoon car.  In my 10 years of ownership the gauges of my 1980 model have never misted up. I don't often have the roof on but we drove back from Goodwood on Saturday through some very heavy downpours and we suffered no water ingress. Don't bother making me offers, I'm never selling! ~iw
Posts: 3,480 Likes: 42
Posts: 3,480 Likes: 42 |
At the risk of seeming a fraud, my2009 is totally waterproof after the installation of various bits of neoprene and draught excluder!!!
However the instruments do mist up!!!
