Topics49,839
Posts837,298
What am I doing up here?
A sad end to a great five day break in Thirsk. On leaving the M62 I touched the brakes and the peddle hit the floor. You don't half push it hard the second time,  nearly went through the windscreen. The offside rear brake slave cylinder pistons had seized, massively overheated the drum and brakes and probably boiled the brake fluid causing bubbles in the fluid. The brakes were smoking when I pulled up. Pistons cleaned and lubed with a tiny bit of copperslip today. This same rear brake overheated a couple of years ago, obviously a poor repair on my part. I must say "Rescue my Car.Com" were really great. Highly recommended and cheap too.
Posts: 37,403 Likes: 977
Posts: 37,403 Likes: 977 |
Thank goodness you didn't hit anything.
Posts: 5,654 Likes: 4
Posts: 5,654 Likes: 4 |
A Lucky escape by the sounds of it.
Martin (Deano)
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
A lucky escape indeed Soggysocks. Glad you are safe and well.
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
Posts: 1,569 Likes: 12
Posts: 1,569 Likes: 12 |
I bet you had to change your underwear after that  . Glad no one was hurt.
Steve L.
1996 Plus 8 N22 MOG
Posts: 2,272 Likes: 7
Posts: 2,272 Likes: 7 |
Wow ,
Caught a bullet there , go out and buy a lottery ticket , it must be your lucky week!
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
re the discussions on disks vs drums, I suppose one advantage of rear discs, they are less likely to drag and overheat with the results you experienced!
Glad it all worked out well...
Posts: 5,587 |
Very glad you and your other half are fine , we all dread having a major failure anywhere but the M62 , nasty place to have this !
Posts: 44 |
Thanks for your good wishes guys. I'm just glad I got some braking with the second push. The pistons really were gungy and seized on a 7000 mile car. I need to use it more!
Montreal Blue Plus 4
