4 members (JD44, CooperMan, Morganmike, BLUE+4), 218 guests, and 51 robots.
+8Rich 95
Posts837,265
#540518 02/11/18 04:04 PM
JMC06 Offline OP
new air Intake for my +8
The original Air Intake is using odd filter ( same diameter as the box , so , no clearence for air ) . And air is taken in the bonnet , so , hot . I add DMC air intake with a hoose linked out of engine ( just behind the right wheel ). Far better.
2 Comments
JMC06 Offline OP
Yes , I aggree : The cast manifold is Uggly . I am looking for a new , Stainless steel . If you have proposals at low price ….
JMC in Morgan +8 ,1998 , 4,6l
I fabricated a similar set up for my +8 using the existing trumpet. Remove the trumpet and filter holder inside the canister, fit a K&N conical filter which allows air flow around the side and through the front of the filter. Fixed a 3 inch air hose to the other end of the canister which goes down and faces forward behind the right front wheel. Works great and just the cost of the filter.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
