5 members (Simon, TalkMorgan, Chris Cosher, TBM, RichardV6), 276 guests, and 102 robots.
+8Rich 74
DaveW 52
Topics49,867
Posts837,627
Moggo
Page 20 of 31 1 2 18 19 20 21 22 30 31
#602934 10/11/19 06:04 AM
3 Images
Image Offline OP
Keith's 4/4 resto
Bringing it home... Runner and driver but various body woes :-)
302 Comments
Image #662065 14/09/20 07:29 AM
You can be proud of your work!
Image #663949 24/09/20 11:09 AM
Image Offline OP
Noticeable shift towards the Wintery up here.
The main Job ..... panels welded in and given some judicious tapping .....( foot-long butt welds on 0.7mm flat sheet aren't any welder's favourite job smile ) .... decent enough result (good enough for me, as I'm not a Pebble Beach Concours judge with a microscope) .... quick shot of primer as it's hard to judge flatness with the colour differences of the steel and welded area ... all to be stripped back for paint now.
Side job ... I like these as they give instant gratification from something started and finished in a few hours .... raided the scrap bin for some stainless sheet and rod plus a bit of brass rod and made a new battery tray .... folded base with the corners stainless welded and polished back .... clamp bar cut from an old bit of stainless box section ..... bent and threaded the J-bolts out of 6mm rod and ran them past the polisher as I couldn't find ready made ones the right length in stainless .... happy enough with that.
Ps the rough line you can see a few inches up on the front bit is the edge of the old paint I ground back to stop it stinking while I was welding .... the welded join is horizontal under the bottom of the weather bead.
Image #663955 24/09/20 11:32 AM
Great job K, power to your elbow. thumbs
Image #663958 24/09/20 11:39 AM
Superb work and the most interesting build thread I have read. First class 👍🏻🍾
Can I please ask What grade Cratex stick did you use for the engine turning?
Cheers John
2011 4/4 - "Elrond"
2007 Elfin C3 Clubman - “Gimli”
Image #663967 24/09/20 12:08 PM
Image Offline OP
Uther ..... it's the fine one (described as reddish brown in their catalogue) ..... as the 3/4 rod won't fit in most normal drill chucks I turned up the holder to take about 2" of it .... you don't want it too long as it may flex and be less accurate ... the rod is hard rubber and just a good push fit in the end) 6" of the rod will last a lifetime unless you decide to engine-turn a passing cruise liner..... was going to suggest I send you the lot to have a play with for a while .... til I saw where you are .... a bit impractical methinks!! smile
Image #663976 24/09/20 12:51 PM
Nice job on the new battery tray thumbs
Image #664070 24/09/20 10:55 PM
Thanks for that info Keith, I have always wondered how this was done. It was a kind thought to loan it to me but yes I am a bit far away making that impractical 😄. I will ordera fine rod locally today, and the photo of your holder is very a handy, I have a good friend with a lathe and will see if he can make me a holder.
I look forward to your next instalment.
Cheers John
Cheers John
2011 4/4 - "Elrond"
Image #664071 24/09/20 10:59 PM
Image Offline OP
John .... if you look back at the pic of the dash sat on the old belt-drive drill press you can see I marked the dash out with a grid with a sharpie .... just a matter of hitting every cross ... helps keep straight and even ... not hard ... just tedious if it's a big area..... good luck with it
Image #664118 25/09/20 09:23 AM
Thanks, I saw that grid then forgot to ask what you used to Mark it with 👍🏻
Cheers John
2011 4/4 - "Elrond"
Image #664158 25/09/20 02:10 PM
Image Offline OP
John ..... the grid was 1/2" x 1/2" to create an overlap of the swirls using the 3/4" rod .... any sharpie that hangs about can be wiped off using acetone or methylated spirit (or whatever that's called in Tasmania smile )
