Noticeable shift towards the Wintery up here.
The main Job ..... panels welded in and given some judicious tapping .....( foot-long butt welds on 0.7mm flat sheet aren't any welder's favourite job
) .... decent enough result (good enough for me, as I'm not a Pebble Beach Concours judge with a microscope) .... quick shot of primer as it's hard to judge flatness with the colour differences of the steel and welded area ... all to be stripped back for paint now.
![[Linked Image]](https://www.tm-img.com/images/2020/09/24/20200924_102613.jpg)
Side job ... I like these as they give instant gratification from something started and finished in a few hours .... raided the scrap bin for some stainless sheet and rod plus a bit of brass rod and made a new battery tray .... folded base with the corners stainless welded and polished back .... clamp bar cut from an old bit of stainless box section ..... bent and threaded the J-bolts out of 6mm rod and ran them past the polisher as I couldn't find ready made ones the right length in stainless .... happy enough with that.
![[Linked Image]](https://www.tm-img.com/images/2020/09/24/20200924_104754.jpg)
Ps the rough line you can see a few inches up on the front bit is the edge of the old paint I ground back to stop it stinking while I was welding .... the welded join is horizontal under the bottom of the weather bead.
