1 members (DJC),
267
38
Topics49,841
Posts837,323
Posts: 1,236 Likes: 40
Boat build
Another experiment in photo posting, this photo was taken yesterday, if this works I will add earlier pictures of the build and bore you all.
Fantastic, it worked, now I can add earlier pictures if there's any appetite for them out in TM land. I might even do it there's not.😂
Gordon Duguid 2014 Duratec engine plus 4, Montreal blue.
Posts: 8,667 Likes: 489
Posts: 8,667 Likes: 489 |
Clever idea to hold the belt sander  , I may adopt this instead of bodging it into the old B&D Workmate jaws
Posts: 1,236 Likes: 40 |
Company work stops early on a Friday so I managed to make a start to caulking the deck. Bit of a learning curve as usual, secret appears to be removing the masking tape when the sikaflex is half cured. I also decided that a gate was the best option for the transom opening. Not hinged in the photo but hinges arrived today so maybe this weekend. ![[Linked Image]](https://www.tm-img.com/images/2021/05/14/IMG_20210514_161201.jpg) ![[Linked Image]](https://www.tm-img.com/images/2021/05/14/IMG_20210514_142905.jpg) ![[Linked Image]](https://www.tm-img.com/images/2021/05/14/IMG-20210507-WA0004.jpg)
Posts: 2,273 Likes: 38
Posts: 2,273 Likes: 38 |
Absolutely beautiful work, credit to you Gordon
Craig Jezz
Posts: 688 |
Porsche 981 Spyder V8 Speedster ( 5 years) 4/4 Competition spec (5 years) 4/4 4str Kent ( 10 years)
Posts: 96 |
Beautiful woodwork and craftsmanship! Well done!
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
Beautiful woodwork and craftsmanship! Well done! +1
Posts: 922 Likes: 1
Posts: 922 Likes: 1 |
Very beautiful, remarkable workmanship
Kevin
Thanks again for your comments. Much appreciated. Progress has been slow over the past 8 weeks or so due to work commitments but most of the caulking is done and I got a couple of coats of Teak protector onto the cabin sides and foredeck hatch tonight. This is a new product to me, I've always used Teak oil in the past. Apparently Teak oil draws the natural oils out of the wood and leads to recoating at an ever decreasing timescale. Teak protector is a water based product that lasts 4 times longer than oil and doesn't draw out the natural oil and is UV blocking. Been getting it wrong all these years You live and learn. Hopefully will get the decks coated and get her outside this summer 🤞 ![[Linked Image]](https://www.tm-img.com/images/2021/07/06/IMG_20210706_195814.jpg) ![[Linked Image]](https://www.tm-img.com/images/2021/07/06/IMG_20210706_195726.jpg) ![[Linked Image]](https://www.tm-img.com/images/2021/07/06/IMG_20210706_195629.jpg) ![[Linked Image]](https://www.tm-img.com/images/2021/07/06/IMG_20210706_195540.jpg) ![[Linked Image]](https://www.tm-img.com/images/2021/07/06/IMG_20210706_195500.jpg) ![[Linked Image]](https://www.tm-img.com/images/2021/07/06/IMG_20210706_195404.jpg)
Great progress, all that caulking must get a bit tedious
Where the glazing fits into the frames flush, will you fashion some sort of Bolection cover bead ?
