5 members (Image, flyfisher, JohnHarris, gomog, Neville1), 259 guests, and 106 robots.
+8Rich 75
Topics49,869
Posts837,656
Moggo
#714306 14/08/21 10:11 PM
8 Images
MATTMOG Offline OP
Loose exhaust
Has anyone had this before?
Always had a strange rattle in the exhaust of Matt-Mog our 2014 +4. I thought a leftover piece of welding wire, couldn't see anything wrong on the outside of the exhaust.
But recently the sound got duller. Especially at idle. So check it again. And yes broken bracket.
A quick provisional repair was necessary. Under the workbench I found something that with a small adjustment could serve as a temporary solution.
In the second photo you can see that on the left side the fracture is stil fresh, no rust.
The other side must have been broken long ago. There from the rattle?
Let's see if Belmog can provide this support? Otherwise DIY I assume???
1990 4/4 1.6 Ford CVH Sold
2014 +4 2.0 Ford
2005 BMW Z4 2.2 6Cyl Sold
15 Comments
HJF #714433 16/08/21 07:44 AM
Originally Posted by HJF
How does that bracket unbolt? Are the fixings going into captive nuts on the chassis or do you somehow have to get a spanner on the other side?
Captives on the inside!
HJF #714534 17/08/21 07:49 AM
There is a plate fitted from inside that has two studs welded to it, so yes captive but studs not nuts. I looked into moving mine when I needed to fit Aero side pipes with shorter silencers. Difficult to access though given trim, seat belt anchor etc.
Note to OP. There is plenty of adjustment with factory setup both vertically and laterally so no need for any tention when re-assembling with new bracket MXC0220, when you can get hold of one. Would suggest, as others have, taking the opportunity to fit stainless bobbins though, also available via SiFab.
MATTMOG #714538 17/08/21 08:25 AM
MATTMOG Offline OP
Are in stock at Belmog thumbs
Going to pick up on Thursday
Hopefully good weather, is a nice ride of som 120Km drive
2014 +4 2.0 Ford
MATTMOG #714572 17/08/21 01:30 PM
Good news Paul and the bonus of a trip out thumbs
MATTMOG #714889 20/08/21 06:41 PM
MATTMOG Offline OP
Installed new exhaust bracket, was not a straightforward job.
https://www.tm-img.com/images/2021/08/20/DSCI0419.md.jpg
With the bracket in lowest there was no room for the rubber bobbins.
https://www.tm-img.com/image/3elqw
Everything had to come loose, including the U bolt and the bracket at the back.
Then jacked up the exhaust a bit to get everything straight.
Lower the rear bracket a bit and then it worked.
https://www.tm-img.com/images/2021/08/20/DSCI0423.md.jpg
Everything reassembled but not tight. Will see the next few days if thing needs to be adjusted.
On the (test) drive to the circuit everything sounded normal.
BTW
Is there a way to add photos directly in a reply to a gallery?
Can only find this way to do it.
2014 +4 2.0 Ford
MATTMOG #714891 20/08/21 07:16 PM
O
BTW
Copy and paste the full image (linked) BBCode, and it should work for you
Craig Jezz
