1 members (Moggo),
288
36
Topics49,841
Posts837,323
And for my next trick...
I am feeling mildly intimidated by this but I expect I shall get through it somehow.
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
It's a breeze once you get going .
Posts: 37,403 Likes: 977
Posts: 37,403 Likes: 977 |
It's all a matter of keeping your cool...
Posts: 1,461 |
I was reading through the instructions and was feeling up to it until this:
"Undo the centre track rod ends from the drop bracket on the steering rack and swing the track rods aside."
This makes me feel that I might exceed my very modest competence and that I should seek a proper mechanic.
I removed the box at the bottom of the cowl, so I didn't need to do that. Although I took them off to fit my Roadster with a steering damper, and it's easy enough.
Posts: 1,461 |
I removed the box at the bottom of the cowl, so I didn't need to do that. Although I took them off to fit my Roadster with a steering damper, and it's easy enough. That is interesting. Happily the allegedly crap OE plastic rad of my 2015 4/4 has not yet (touch ash) sprung a leak, so I have time to think about this. And I have a couple of local friends with more skill than wot I have whom I shall consult before taking the next step. The SIFAB kit looks very nicely engineered and is astonishingly light. Alas, the reasonable price had 140€ in tax added to it on the way to France, thanks to Brexit.
Posts: 8,667 Likes: 489
Posts: 8,667 Likes: 489 |
It's all a matter of keeping your cool... Yes Richard, I see what you did there
Posts: 1,415 |
I removed the box at the bottom of the cowl, so I didn't need to do that. Although I took them off to fit my Roadster with a steering damper, and it's easy enough. It's much easier to undo the centre track rod ends, and it gives you space where you need it. I might have done quite a few radiator swaps....
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Posts: 8 |
I managed to change my Roadster radiator for a new Sifab one just by jacking the front end up and no need undo the track rod ends. Old one needed a little jiggling to get out but not a difficult job at all
Posts: 1,461 |
I managed to change my Roadster radiator for a new Sifab one just by jacking the front end up and no need undo the track rod ends. Old one needed a little jiggling to get out but not a difficult job at all Thnaks for that. Perhaps the 4/4 is not as easy...
