6 members (Aeromax51, Mike D, Gordon D, Mikemog6, Ncik P, Doug J), 133 guests, and 65 robots.
+8Rich 76
Topics49,860
Posts837,523
Jonny72
Page 4 of 4 1 2 3 4
Originally Posted By cerealsurfer
I'll talk to dad this weekend to see if a two piece "Millers" could be created using a smaller diameter tube which could be welded inside the existing handle to create a strong slotting removable joint.
Cerealsurfer. I forgot to ask you dad last Thursday. Any news on this?
A11OGE #100976 13/08/12 07:19 AM
Hi,
Well I am having another go at removing a tight nut on the front passanger side.
It is completely stuck. I want to remove it to put spinners on the car.
I have tried the Millers Spanner but have no luck, it does have a issue of slipping of the nut a bit.
I have even tried a 4lb hammer but still it wont budge.
Any other suggestions? Does the centre lock plus 8 / aero wheels have the same issue from memory?
Thanks,
Will
Dear Will,
i had the best results gently heatening up the nuts for some minutes with a heat gun in advance. thumbs
If the´d been lubricated properly when fitted last time, they will come off with ease then... (hopefully! cheers)
drive 2015 Roadster 3.7
numog #101012 13/08/12 01:38 PM
I agree, one of those paint stripper-offers, less vicious than a torch of any sort but still hot enough.
Simon
2002 4/4
2021 Audi A1 sport
Guten #101017 13/08/12 02:42 PM
I have the Miller tool which is fine but the front tend to get tight maybe from the disc oe engine heat.
Sometimes they need a bit of persuasion first by the standard tool and hammer.
Page 4 of 4 1 2 3 4
