Topics49,866
Posts837,588
Posts: 4,612 Likes: 15
Posts: 4,612 Likes: 15 |
I'll talk to dad this weekend to see if a two piece "Millers" could be created using a smaller diameter tube which could be welded inside the existing handle to create a strong slotting removable joint. Cerealsurfer. I forgot to ask you dad last Thursday. Any news on this?
Posts: 1,105 Likes: 17
Posts: 1,105 Likes: 17 |
Hi, Well I am having another go at removing a tight nut on the front passanger side.
It is completely stuck. I want to remove it to put spinners on the car.
I have tried the Millers Spanner but have no luck, it does have a issue of slipping of the nut a bit.
I have even tried a 4lb hammer but still it wont budge.
Any other suggestions? Does the centre lock plus 8 / aero wheels have the same issue from memory?
Thanks, Will
Posts: 1,127 |
Dear Will, i had the best results gently heatening up the nuts for some minutes with a heat gun in advance. If the´d been lubricated properly when fitted last time, they will come off with ease then... (hopefully!  )
It doesn´t matter how fast it becomes, but how it becomes fast.  2015 Roadster 3.7
Posts: 521 Likes: 2
Posts: 521 Likes: 2 |
i had the best results gently heatening up the nuts for some minutes with a heat gun in advance. I agree, one of those paint stripper-offers, less vicious than a torch of any sort but still hot enough.
Simon 2002 4/4 1936 Austin 12 light 4 Ascot saloon 2023 AMG Mercedes C300e estate 2021 Audi A1 sport
Posts: 27,814 Likes: 749
Posts: 27,814 Likes: 749 |
I have the Miller tool which is fine but the front tend to get tight maybe from the disc oe engine heat.
Sometimes they need a bit of persuasion first by the standard tool and hammer.
