7 members (Chris99, BillHart, CLPlusFour, Jens, hugo, RedThree, Rog G),
292
Topics48,357
Posts813,257
Members9,215
Posts: 7 |
I just lost my indicator lights while travelling at night in France. I suspect it may be the fuse. Could someone please let me know which is the fuse for the indicators (+4 from 2008) ? Even better if you have the card for the fuse box (I don't think I got it when I bought my car). I am driving back to the UK tomorrow and indicators would come handy ;-) Many thanks Guillaume
Posts: 3,643 |
tmg513 thanks for posting. Very useful.
Posts: 2,515 |
1972 4/4 2 Seater
Posts: 7 |
No luck so far. Got back without the indicators ... I tried all the 15amp fuses with no success. Will check the other ones in the next couple of days. Could it be something else than the fuse ? Thanks
Posts: 14,976 Likes: 1
Posts: 14,976 Likes: 1 |
Could be the flasher unit?
Richard 1976 4/4 4 Seater
Posts: 2,515 |
As Richard says it could be the flasher unit or the switch itself. Do the hazard flashers work? If so, and I'm assuming there are two flasher units like on my car, swap the hazard flasher unit with the normal one.
Whereabouts in France are you?
1972 4/4 2 Seater
Posts: 7 |
I was in Dordogne for the week with a fantastic weather ... what a great car to drive on the Perigord's country lanes, but now back to London ! Re. the indicators, the hazard lights are out as well. I will try and test all the fuses ... may be easier ... May be a dummy question, but can you explain the difference between the flasher unit and switch (fuse?) Thanks
The flasher unit in effect turns the power to the indicators (or hazards) on and off so the "flash", the switch is (normally) the indicator lever that provides power to the flasher unit.
If you have a multimeter best to check for continuity of the fuses with this. A visual check of the fuses is not always the best.
Posts: 28,428 Likes: 180
Posts: 28,428 Likes: 180 |
A visual check of modern fuses can totally miss a blown fuse (had that with "booty's" +4). An ohmeter is always best...
Sold L44FOR 4/4 Giallo Fly '09 Gen2 MINI Cooper ragtop '90 LR 90 SW
