6 members (KennyW, jbk, Topline123, Roady, Alan Patterson, TalkMorgan), 228 guests, and 11 robots.
John V6 79
+8Rich 69
DaveW 67
Luddite 57
9,203 Registered Users
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Goggle eyed
by Roady - 19/07/25 06:16 PM
by t50 - 19/07/25 12:07 PM
Lions Tour
by OZ 4/4 - 19/07/25 11:55 AM
Morgan rebuild on Facebook
by TBM - 19/07/25 10:50 AM
Topics48,337
Posts812,913
Members9,203
toitoine
#101522 18/08/12 10:45 PM
gq1 Offline OP
I just lost my indicator lights while travelling at night in France. I suspect it may be the fuse. Could someone please let me know which is the fuse for the indicators (+4 from 2008) ? Even better if you have the card for the fuse box (I don't think I got it when I bought my car). I am driving back to the UK tomorrow and indicators would come handy ;-)
Many thanks
Guillaume
gq1 #101524 19/08/12 01:10 AM
Bad luck. According to the GoMog wiring diagram for 2006- +4
http://www.gomog.com/allmorgan/Roadster~Plus4_Chassis_Harness.pdf
Fuse 10 (15 amp should be light blue) is for indicators and headlight flash.
1972 4/4 2 Seater
tmg513 #101567 19/08/12 03:33 PM
tmg513 thanks for posting. Very useful.
Ian
Wirewheel #101605 19/08/12 06:11 PM
Hope you get it sorted.
1972 4/4 2 Seater
tmg513 #101629 19/08/12 08:27 PM
gq1 Offline OP
No luck so far. Got back without the indicators ...
I tried all the 15amp fuses with no success. Will check the other ones in the next couple of days. Could it be something else than the fuse ?
Thanks
gq1 #101634 19/08/12 10:04 PM
Could be the flasher unit?
As Richard says it could be the flasher unit or the switch itself. Do the hazard flashers work? If so, and I'm assuming there are two flasher units like on my car, swap the hazard flasher unit with the normal one.
Whereabouts in France are you?
1972 4/4 2 Seater
tmg513 #101714 20/08/12 09:38 PM
gq1 Offline OP
I was in Dordogne for the week with a fantastic weather ... what a great car to drive on the Perigord's country lanes, but now back to London !
Re. the indicators, the hazard lights are out as well. I will try and test all the fuses ... may be easier ...
May be a dummy question, but can you explain the difference between the flasher unit and switch (fuse?)
Thanks
gq1 #101715 20/08/12 10:06 PM
The flasher unit in effect turns the power to the indicators (or hazards) on and off so the "flash", the switch is (normally) the indicator lever that provides power to the flasher unit.
If you have a multimeter best to check for continuity of the fuses with this. A visual check of the fuses is not always the best.
A visual check of modern fuses can totally miss a blown fuse (had that with "booty's" +4).
An ohmeter is always best... smile
'09 Gen2 MINI Cooper ragtop
