6 members (JoeSpeetjens, Laurens, sbarracl, Mike D, MartinB60, Topline123), 183 guests, and 60 robots.
+8Rich 76
Topics49,860
Posts837,520
Jonny72
Page 3 of 3 1 2 3
Hertford Mog #111443 13/11/12 01:49 PM
Leaf spring sort of squeak?
If so, jack up eack back corner and spray motorcycle chain wax in between each leaf of the rear springs.
Bud
__________
2003 - 4/4
Bud
4/4 "Stanley"
Budster #111474 13/11/12 04:27 PM
I had that squeak too. Greased the rear springs and packed them with grease-filled gaiters to no avail - it were the wirewheels as I found out much later...
1967 4/4 1500 Comp.
1935 Super Sports Barrelback
Bodger #111527 14/11/12 11:08 AM
I'm pretty sure it's the suspension. If you rock the rear of the car up and down even slightly you get a loud squeaking noise. I'm determined to sort it though so thanks for the suggestion. Everything else about the car is absolutely perfect (!!)
Hertford Mog #111532 14/11/12 12:32 PM
Just so long as the squeaking isn't due to the same problem as in this previous thread...
http://www.talkmorgan.com/ubbthreads.php/topics/91552/1
Giles. Mogless in Paris.
pandy #111533 14/11/12 12:39 PM
That had me worried until I read the thread ..... no, that's not the problem - though previous experience says it was easier to deal with mice in the garage than stop the rear suspension squeaking !!!
Wirewheel #111584 15/11/12 07:39 AM
Originally Posted By Wirewheel
Only issue was paint falling off cowl badge and the wrong headlamp rim, slightly too large ; both replaced by factory under warrantee at first annual service.
Washed the car the other day and the left hand headlight rim came off at the top. I popped it back on but I think it could easily come off again on a bump. scared
Gambalunga #111588 15/11/12 08:03 AM
There should be a screw on the underside - bit of a fiddle with the shape of the wing...
Cheers,
Gambalunga #111593 15/11/12 09:04 AM
Hi Peter, our cars are similar age.
I had the same issue, fixed under warrantee.
The incorrect headlamp surround was fitted on the one side. In my case it was the near side. It did come off but was retained by the screw. Put a bit of masking tape across the rim and the body until you get it fixed.
To confirm, if you take off both rims and then put them back to back you may see a slight inference in size.
Ian
Page 3 of 3 1 2 3
