Topics49,859
Posts837,498
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
Leaf spring sort of squeak? If so, jack up eack back corner and spray motorcycle chain wax in between each leaf of the rear springs.
Bud
__________ 2003 - 4/4
Bud 4/4 "Stanley"
Posts: 462 |
I had that squeak too. Greased the rear springs and packed them with grease-filled gaiters to no avail - it were the wirewheels as I found out much later...
1967 4/4 1500 Comp. 1935 Super Sports Barrelback
Posts: 32 |
I'm pretty sure it's the suspension. If you rock the rear of the car up and down even slightly you get a loud squeaking noise. I'm determined to sort it though so thanks for the suggestion. Everything else about the car is absolutely perfect (!!)
Posts: 8,646 |
Just so long as the squeaking isn't due to the same problem as in this previous thread... http://www.talkmorgan.com/ubbthreads.php/topics/91552/1
Giles. Mogless in Paris.
Posts: 32 |
That had me worried until I read the thread ..... no, that's not the problem - though previous experience says it was easier to deal with mice in the garage than stop the rear suspension squeaking !!!
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
Only issue was paint falling off cowl badge and the wrong headlamp rim, slightly too large ; both replaced by factory under warrantee at first annual service. Washed the car the other day and the left hand headlight rim came off at the top. I popped it back on but I think it could easily come off again on a bump.
Posts: 28,899 Likes: 352
Posts: 28,899 Likes: 352 |
There should be a screw on the underside - bit of a fiddle with the shape of the wing...
Cheers,
Posts: 3,643 |
Hi Peter, our cars are similar age. I had the same issue, fixed under warrantee. The incorrect headlamp surround was fitted on the one side. In my case it was the near side. It did come off but was retained by the screw. Put a bit of masking tape across the rim and the body until you get it fixed. To confirm, if you take off both rims and then put them back to back you may see a slight inference in size.
