8 members (Guern, Doug J, Ian Wegg, Dek, Bunny, Ritchie B, Liam1961, DickJ), 201 guests, and 79 robots.
+8Rich 76
Topics49,861
Posts837,531
Jonny72
1234 Offline OP
Hi, can anyone tell me how to remove the front grill from a 56 +4? Thanks, Bill
If I might be so bold as to assume this has never changed, you should find two bolts behind the bottom band on the grille. Remove these and the grille will slide downwards. Thats how it comes off on my 2005.
And my '76... smile
And my '76... smile
And my '75 4 seater.
cheers
Neil.
1975 4/4 4 seater, cream over blue; Q3 Quattro; Bicycle; Walking poles.
I looked at a stainless steel grill a while back and it fitted all models save for a few in 1950's which had the "long" grill so I suspect all are the same as Dave says.
Mine is the same
Posting Desperado
Posting Desperado
Beware as you slide it back one slip and you can chip off the paint on your cowl . You have to be as steady as a Jock putting his hand in his pocket .
In that case the grill might not be coming off then! rofl rofl
Philip.
Is this for fitting a mesh inner grille? In which case a blow-by-blow account from someone who has already done it would be really useful!
Nigel
Ooooo! Nigel, I thought that Dave's explanation above was pretty clear with several supporting +1s. Maybe there's more to the terse reply.... being a Lancastrian we tend to have a similar view of the White Rose clan as those North of the border when it comes to being "careful" with the small change, stereotypically that is smile
Philip.
