8 members (MJF, High Hamster, CLPlusFour, Arwyn Williams, RedThree, MartinB60, A11OGE, BobtheTrain),
287
41
Topics48,362
Posts813,320
Members9,215
Posts: 36 |
Traction control would not be a bad thing to add to the M3W. I imagine the rear wheel breaking loose with very little provocation in its current guise.
- Samwisekoi
Posts: 3,514 Likes: 8
Posts: 3,514 Likes: 8 |
I'm not so sure that driver aids like traction control are always a good thing on a sports car, it's better to learn to control the car with skill and experience.
I agree that the S&S engine is a little rough and would benefit from being smoothed out a bit, maybe a balancer shaft, if it doesn't already have one? The vibrations at certain speeds go beyond 'character' in my opinion, though by no means awful or a reason not to love the car.
Posts: 1,947 |
A V twin of nearly 2 litres will vibrate, full stop. If you add a balance shaft, you will be adding a lot of weight to the engine, and a lot of inertia, thus impeding responsiveness.
"thus impeding responsiveness." Oh no, you do not want to do that, we'll stick with the mobile vibrator then, thanks.
Posts: 8,646 |
A V twin of nearly 2 litres will vibrate, full stop. If you add a balance shaft, you will be adding a lot of weight to the engine, and a lot of inertia, thus impeding responsiveness. True dat. However, to go back to the aforementioned Guzzi engine, a 90° twin will have better inherent mechanical balance than a 56.25° one.
Giles. Mogless in Paris.
