5 members (Image, Graham, G4FUJ, Mog on Island, RedThree, Tweed19er), 281 guests, and 29 robots.
John V6 65
DaveW 63
+8Rich 62
Dufty, Anted4, 4199, GOFFO1965, Joske Vermeule
9,212 Registered Users
First Morgan
195/60 R15 for 2018 Plus4
by Soleng - 24/07/25 05:32 PM
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Topics48,349
Posts813,103
Members9,212
aeroed, DJC, James Mc, JimWhin
art Offline OP
Initially I thought there was a problem with the starter motor and the fuel pump normally buzzes when the ignition is turned on. Everything else was working, lights etc. Only by chance I tried my spare key and everything was OK to my relief.
So now I'm without a spare key. What I was wondering, can I repair the old key and fob ? Is it just a matter of changing the battery or what ? thinking any advice much appreciated - Keith
'99 Morgan+8 4.6
'35 Hudson Terraplane Sedan
'35 Hudson Teraplane Coupe
'10 Alfa Romeo Mito
Do you mean Key or immobiliser remote (plipper)? If the key, then I can't think of anything that would cause that.
Using the remote, if you arm the alarm you should hear a relay click, if you cannot hear it then in the first instance change the battery.
If the other remote is working then odds on it is the battery, however if needs be you can buy a new remote but they will need re-programming by someone with the appropriate ODB2 software
art Offline OP
no click heard when arming remote, I'll try changing the battery in the remote.
Thanks a lot Brian
'99 Morgan+8 4.6
'10 Alfa Romeo Mito
from: http://www.talkmorgan.com/ubbthreads.php/topics/118791/2010_Morgan_4_not_starting#Post118791
..."the immobiliser module in the Ign key had dropped out..."
"The module is the small 2/3mm dia black 'pimple' on front edge of plastic section of the key and is approx 20mm long. Make sure yours is firmly stuck in"
-99 4/4, 1.8 Zetec, Indigo Blue, 2-seat, Suplex RS
-04 Citroen Pluriel, 1.6 Sensodrive, Met Orange
art Offline OP
Just changed the battery in the remote plipper - all ok now. The immobiliser wasn't even armed. Its certainly worth carrying spare batteries in the car. I had been about to call an auto electrician which would have been very expensive. Also lucky I was at home just about to warm up the car as it is on sorn at the moment until May.
Cheers all - Keith
'99 Morgan+8 4.6
'10 Alfa Romeo Mito
I carry spares for the Toyota as there not easy to get hold of. Eventually found some in a jewellers.
