Morgan Aero 8
5 members (DickJ, Ncik P, Robbie, TBM, DCH), 367 guests, and 88 robots.
+8Rich 77
Topics49,868
Posts837,640
Moggo
Page 3 of 4 1 2 3 4
Chris, I have finally fitted my PC925 including the cleaning of the positive terminal area below the washer bottle. This appears to be a junction for a number of leads, including the positive cable running to the starter. There was some sulphur build up on that connector which may have been unhelpful.
The car started with a very lively turn over with the battery straight out of the box. I have put the battery conditioner, CTEC, in place with the setting for trickle at the highest, hopefully it will survive for a season or two.
Dave
This winter I had the car in a friends "open fronted" barn and all I done was isolate the car (the red "button") and after six weeks it started straight away - no trickle charge etc. So I am more confudsed with the issue with these type of battery's failing so much. Anyway, its good news!!
15 Weissman GT5
11 Aero8 SS
21 Q7
23 RR
24 Def'r 130
1960 XK150 DHC
1970 E-type
2024 Huracan Tech
Did you check you mileage, your friends may have been giving it a run on your behalf.
Good news though. thinking
Ian
Does anyone know what the mog works racing tweak is ?
There's nothing on their website.....
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Sorry, not aware of a racing tweek, but would be interested.
Incidently the new battery is still performing well after 6 months, never missed a start, unlike one before.
Taffmog,
Drop them a line 01494 448158 they'll be happy to talk you through what is done.
Thanks, will do, I am beginning to have a problem now and again at 29,000 miles, not sure if it's the motor or the battery as yet. Aero starter motors appear to fail at 24-30 k miles ?.
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Aero starters fail on a cycle. The duration to first failure can vary from 10k to 25k miles ish.... but after that they fail on a steady frequency.. though most people don't rack up the mileage for it to be a problem.
The trick is making sure you use a quality part as a replacement and to use a process which makes this job almost a serviceable item.
Always clean the wiring at the same time as this is clearly a contributing factor as you observe.
Hello, I installed a new Odyssey battery a couple of years ago (the previous was was 9 years old) when I started to get the clicking. With the new battery the problem disappeared but now it's doing it again.
I cleaned all the terminals and electrical junctions I could get to but no improvement. So to start I had to keep pressing the start button for 1-2 mins and eventually it starts; not an ideal situation.
Not convinced that my battery was tired already I thought I'd test it by putting a jump lead from the +ive terminal of the battery to the + block at the front of the engine. The car starts every time when I do this telling me that there's a problem on the + ive side to the starter from the battery. Wings are due off shortly for the annual service so I hope to be able to find the culprit then.
Cheers
Philip
1985 Plus 8 four seater
Malone F1000 - track car
Have you checked the earth lead to the starter motor?
Page 3 of 4 1 2 3 4
