7 members (DCH, stefan s, Paul F, Alan Patterson, Moggo, Ian Wegg, britmog), 282 guests, and 37 robots.
Adam12 69
+8Rich 67
John V6 59
9,215 Registered Users
SORN
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,367
Posts813,395
Members9,215
Rbt Aero8, Salmon, stevends
Randall Offline OP
Hello all, seems I have an engine monitor light showing. Have had it into service center,they plugged in and tell me it's an error code that says both banks on my ford cyclone 3.7 motor are running lean. They also said it happens alternately one bank then the other. They have checked all the obvious points sender,hoses,etc. They have contacted Morgan and got the response that they have never had this issue before and just left it at that. I am not sure if when driving and when accelerator is pushed down I seem to get a wee pause sort of like a gasp then another go (noticeable but not serious) is this common or should it accelerate right to the top of rev range? Any ideas or suggestions would be appreciated. Many thanks Randall (New Zealand) Ps have done 7000 km
Morgan Roadster 3.7 2012 Spruce Mica Green Saddle Brown Interior
I'm not familiar with that engine but it sounds to me as though you have a faulty or badly adjusted throttle position sensor. There are also other sensors that effect the fuel air mixture. The fact that it is happening on both sides would tend to indicate one of the sensors that effects the amount of fuel supplied. This could be air pressure, temperature, mass air flow or throttle position. I'm surprised a competent service center can't locate the problem.
Check the exhaust isn't blowing at the silencer joints and check for loose clamps
Drive on the Wild Side
Could be a dodgy lands sensor muddling up the ecu
Adrian
Randall Offline OP
That may be but ohaving only one dealer and seemingly no support from MMC it's not good.
Make sure the right Catalytic Converter/s are fitted. My 2012 +4 had the wrong one fitted and therefore thought the engine was producing incorrect emission levels and warned me by showing engine warning light. I reported it to Morgan immediately and on a recent trip to Williams had the converter replaced (under warranty)and the car checked. I appreciate that's not maybe as simple for you but I'm sure there's a way to check part numbers etc.
Hope it gets sorted.
Randall Offline OP
Cheers will take all suggestions to workshop and see it helps.
Hi Randall
I don't have the engine lights showing on my 3.7. But I do have the slight "gasp" when I press on the accelerator - but no appreciable puse before the acceleration kicks in. I think this is normal but other 3.7 owners can chip in on this.
David
2020 Roadster 3.7 Dove Grey.
Good to see the factory have leapt on this and are being supportive.
Is there another 3.7 owner in NZ? I'm wondering if you could swap ECU's (they're easy to swap out). Having said that, I doubt the ECU would suddenly start misbehaving.
Do you have an OBD II scanner? Or have you looked up the fault codes?
A scanner is not expensive, might be worth getting one - clearing this code and seeing if develops again.
Can you pull a plug and take a look at its condition?
Could it be an oxygen sensor? Would that cause a lean code?
Do you drive at altitude?
Sorry - I'm just firing thoughts at you.
+8 4.8
My ECU on my +4 a Rover T16 engine had an intermittent fault affecting the idle.
Swapping it sorted it.
2025 MG ZS EV aka Trigger
