Topics49,843
Posts837,343
Posts: 27,807 Likes: 749
Posts: 27,807 Likes: 749 |
+1 I spray on bike chain oil. It makes a big difference
Posts: 1,444 Likes: 9
Posts: 1,444 Likes: 9 |
+1 I spray on bike chain oil. It makes a big difference Do you need to lift the car to access the springs or can I just crawl underneath
David 2020 Roadster 3.7 Dove Grey.
Posts: 3,480 Likes: 42
Posts: 3,480 Likes: 42 |
+1 for Chain grease -- Just put it up on Axel Stands. A car creeper to lie on then makes it do-able. If you can get your friendly local garage or tyre place to let you use their lift it is MUCH easier though!!
Cheers!
Great - thanks Robbie. Neilda also recommended something for me to use, but I can't remember the name.Obviously Vaseline won't do the trick
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
It was chain wax.  I'm not sure a human would be able to get under a Morgan without it being jacked up and on stands. Always use stands.
+8 4.8
It was chain wax.  I'm not sure a human would be able to get under a Morgan without it being jacked up and on stands. Always use stands. Chain wax - that was it. Thanks Neil
I bought a tool like this on E-Bay a year or two back. It forces the leaves apart and you apply a grease gun to the end. Thanks Mike. I will look out for that tool.
Posts: 28,892 Likes: 350
Posts: 28,892 Likes: 350 |
David, you must be incredibly slim if you are going to crawl under a Morgan with no form of lifting!!!  I have been able to do part of my rear springs from above, but as the car still needs to be lifted to do the rest, might as well just get it in the air. I do miss the garage at my old place - and its full length/depth inspection pit! Cheers,
David, you must be incredibly slim if you are going to crawl under a Morgan with no form of lifting!!!  I have been able to do part of my rear springs from above, but as the car still needs to be lifted to do the rest, might as well just get it in the air. I do miss the garage at my old place - and its full length/depth inspection pit! Cheers, I have lost a stone in weight since Christmas, Graham  Even so, I would find it difficult slipping underneath  An inspection pit would make life easier - but I think my father has some stands. If not, I am sure my dealer will oblige. Sounds like a small job.
Well done  . My attempts at losing 7 have not got very far - maybe a half at most! Cheers,
