1 members (ChrisConvertible), 206 guests, and 89 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
Page 4 of 5 1 2 3 4 5
+1 I spray on bike chain oil. It makes a big difference
Do you need to lift the car to access the springs or can I just crawl underneath confused2
David
2020 Roadster 3.7 Dove Grey.
+1 for Chain grease -- Just put it up on Axel Stands. A car creeper to lie on then makes it do-able. If you can get your friendly local garage or tyre place to let you use their lift it is MUCH easier though!!
Cheers!
Robbie
2021 Plus Four -- Helga
211-WX-1433
Great - thanks Robbie. Neilda also recommended something for me to use, but I can't remember the name.Obviously Vaseline won't do the trick oops
David
It was chain wax. smile
I'm not sure a human would be able to get under a Morgan without it being jacked up and on stands.
Always use stands.
+8 4.8
Always use stands.
Chain wax - that was it. Thanks Neil cheers
David
Originally Posted By Mike Hughes
I bought a tool like this on E-Bay a year or two back. It forces the leaves apart and you apply a grease gun to the end.
Thanks Mike. I will look out for that tool.
David
David, you must be incredibly slim if you are going to crawl under a Morgan with no form of lifting!!! grin2
I have been able to do part of my rear springs from above, but as the car still needs to be lifted to do the rest, might as well just get it in the air.
I do miss the garage at my old place - and its full length/depth inspection pit!
Cheers,
Cheers,
I have lost a stone in weight since Christmas, Graham thumbs Even so, I would find it difficult slipping underneath innocent
An inspection pit would make life easier - but I think my father has some stands. If not, I am sure my dealer will oblige. Sounds like a small job.
David
Well done thumbs.
My attempts at losing 7 have not got very far - maybe a half at most!
Cheers,
