Morgan Aero 8
5 members (Strathaven, Deejay, B3MOG, BobtheTrain, Simon), 120 guests, and 49 robots.
+8Rich 82
Topics49,859
Posts837,498
Jonny72
Ale_72 Offline OP
Ciao,
please any hint more than welcome.
If I solve it within today it's great, if not tomorrow I'll call the service, but I'll be in Germany and I guess it will not be that easy to sort it out.
Today I was checking radio connections (antenna cable) since the FM tuning was quite poor.
I double checked all connections (even the first time installation was done my myself) but when I put everything back in place the car was not starting anymore.
What's happening
the radio was switched off on purpose. It's working.
- Engine light ON
- SRS light ON longer than usual (but maybe it's just me noticing it)
- Start button not switched on
Useful (maybe) info
- Battery is not flat
- I disconnected the radio and tried to start the car
- I already took away the radio and checked all cables behind (at least the ones I can see).
- I checked fuse box and all fuses seem ok
- All interior lights works properly
- Headlights ok
- Power windows ok
- Central locking ok
- Remote boot opening ok
- Boot opening with the button not working
- No lights in the dash buttons
Please, any idea, even obvious, more than welcome.
I have tried reading this:
http://www.talkmorgan.com/ubbthreads.php/topics/115306/Help_Not_starting
To reset the the inertia switch on the fuse box do I have to press the right button until a small wing comes out on the side and push this wing back in place? if yes, already tried it.
Did you pull the headunit out (stereo)?
If so, have you caught the cable that runs to the START button?
They are in close proximity; hence my question.
le Asbo du Bling
le Asbo du Bling
Funnily enough I've had the radio out on my aero today to put in an aerial switch. I know you've probable checked this but have you knock the shift leave out of park? If you have it won't start.
Sorry if I'm teaching you to suck eggs. Other than that you've got a lot of wiring behind the dash, have you dislodged a wire from the starter?
Slowly going green
Ale_72 Offline OP
Yes.
I tried to look at it but it seemed to me to be fine.
But for sure there is something disconnected since no button has light. I cannot just understand where to check
Yes, shift checked, it was in parking (but later I'll go again to check it).
Behind the dash there were only who whitish connectors and they were properly connected.
Meanwhile the video is uploaded (if it helps)
le Asbo du Bling
le Asbo du Bling
Checked mine and the lights on the same level as the started button should be illuminated.
My guess given they are all of is that you've loosened a cable or a joining box. Have you tried it with the radio out?
Slowly going green
Ale_72 Offline OP
Yes, I agree. It must ne a joining box frown
Yes, I tried with the radio out but with no luck.
Sigh.
Do you need to depress the clutch to start the engine? Could the clutch switch be at fault?
Having said that, the start button would still illuminate.
How frustrating.....
+8 4.8
Ale_72 Offline OP
It's automatic. And you do not have to press the brake pedal as well.
Tomorrow I asked my mother to call them since I'll be travelling the whole day abroad. I hope she succeed to have an appointment. Trying to solve it from Germany it will not be easy.
Dead as a Dodo is sometimes better than flapping on the perch - if you know what I mean. It will be something simple. (Famous last words!).
+8 4.8
Ale_72 Offline OP
I hope so since it's in a underground garage with a curve to get out and it would not be easy to take it out.
