Topics49,846
Posts837,384
Posts: 6,538 |
Had new manifold seals fitted and the problem is 98% solved!
Neil
Posts: 417 |
very interesting. wonder if that's a morgan specific part or something that could be sourced elsewhere. any idea? b Had new manifold seals fitted and the problem is 98% solved!
blake sfmorgan.tumblr.com
Posts: 1,338 |
Guys say you get the newest software installed.and later on you disconnect the battery will it get deleted or not?just wondering because my m3w will be air freighted to kuwait,will i have to reprogram the ecu?
Posts: 417 |
you should be just fine q8 as i swapped my battery out 3 times during the whole rectifier mess and it kept it's ECU map. Guys say you get the newest software installed.and later on you disconnect the battery will it get deleted or not?just wondering because my m3w will be air freighted to kuwait,will i have to reprogram the ecu?
Posts: 1,338 |
With those steel struts mounts,did you feel any difference?can i use the normal brackets that come with the filter or these struts are a must after a few drives?
