8 members (MJF, Alistair, nick w, John Winn, TeddyAds, Martin W, Julian BB, Pigiron), 374 guests, and 38 robots.
+8Rich 92
Topics49,839
Posts837,298
Page 15 of 17 1 2 13 14 15 16 17
Originally Posted By nputtick
A quick question - after mine was fitted I wasn't given the two C-spanners. Do I need these, for future adjustments perhaps?
Nigel
Yes, definitely. They form part of the kit, whoever fitted it should have given them to you.
I checked mine after getting home from the dealer and discovered the right side was too high. It is difficult but possible to make the adjustment with the car on the ground and the wheel turned towards the opposite side.
To check the adjustment you need an absolutely level pavement and you need to bounce the front end a bit, turn the wheel a little from side to side. The instructions are in the kit. When it is correctly adjusted you should be just able to turn the lower spring by hand. Once correctly adjusted they should be ok for quite a long time.
PJB Offline
Also to add, the spring material used for the SUPLEX springs is a very high grade and is not expected to creep, ie loose height, with time. However there may be a little settling after a few miles as the main spring settles into the thrust race rubber seal, thus it is recommended in the instructions to check and readjust if necessary with the supplied 'C' spanners. Then that will be it.
Best regards PJB.
PJB #149867 16/08/13 05:07 AM
I had my kit fitted yesterday - really pleased - no "nodding", much better steering, potholes no longer sent the car offline in a corner and much less vibration from the steering wheel. Early days, but delighted with the initial experience.
Robbie
2021 Plus Four -- Helga
211-WX-1433
That wasn't your car down at Williams was it Robbie? There were a couple of cars from your neck of the woods there yesterday with Lawrie finishing off a cream one and a car very like yours outside.
PJB #149872 16/08/13 05:20 AM
Originally Posted By PJB
Much of this has been answered by others, thanks to them all ~ however:
1. MMC response: The first time the Morgan test drivers drove a car so fitted with the SUPLEX Refinement System (Initially referred to as a 'Comfort Pack' in the development phase) they were impressed enough to want to try it themselves. They are now working with SUPLEX on further developments.
2. Shimmy: It is of course not the SUPLEX RS kit that causes shimmy, though the loss of friction by no longer having a compressed rebound spring will further reduce the friction in the steering. It is well known that removing the friction steering damper/blades and fitting ball thrust races can result in shimmy, hence the need often in those cases for a hydraulic steering damper, like used on many modern sports cars.
3. Lack of bump travel: this is one of the reasons why the rising rate spring characteristic is so beneficial, one can still have a soft initial spring rate for ride comfort yet no crashing through on big bumps as the spring rate increases to prevent it, another Morgan suspension guru was a little mistaken previously on this point too.
4. Rebound spring. A very stiff rebound spring together with rising rate mains gives significantly increased roll stiffness with good ride. Hence the very stiff rebound spring that never goes coil bound.
5. Specific damper: Every change of spring rate, whether linear or nonlinear/rising rate needs a new damper setting up, as on ALL cars by all car companies. That is what SUPLEX did with Bilstein. Bilstein does not list a damper for Morgans as they supply their damper with the SUPLEX kit. It will not work well with other spring rates of course. High and low speed bump and rebound settings are quite unique in this Bilstein damper matched to this rising rate spring system, so other dampers from other reputable manufacturers will not work as well as the specified Bilsteins on this spring system. Hence matched springs and dampers.
6. Different weights: the system was set up for a mid weight car but has been extensively tested from 750kg up to 950 kg (unladen) with no significant change in ride. Engines from 1.6 IL4, to 3.9 V8 and 3.7 V6. The ride frequency, which is what one feels, changes by only 6% between a 850kg car and a 950 kg car, so very little noticeable difference. Also the rising rate in bump means that in roll the spring rate increases as the car starts to roll, so a heavier car settles at a higher spring rate in roll, that in this case is less than a car on stiff linear main springs.
7. Adjustable height: The threaded shrouds with spring seats are there to accommodate the range of weights of cars so that the hub's static position on the kingpin can be adjusted to just kiss the rebound spring as required.
8. The SUPLEX RS was developed by SUPLEX UK Ltd in the UK headed by Dan White, I worked as an engineering consultant and test driver during the development of the spring rate and damper settings. Something I have done of many cars, trucks and military vehicles since the 1970's for many companies.
Morgan dealers with decades of road and track experience have tried the system and recommend it, including pleasingly Librands who also market the double wishbone system so well built by Peter Mulberry.
I hope that this has helped those that have been confused or misslead, but maybe I have met 'Quicksilver' before? Best regards PJB.
That's very interesting. Thank you for taking the time to post. I don't think we have met before cheers
David
2020 Roadster 3.7 Dove Grey.
Jays,
Yes that was mine and another PaddyMog mate - Suplex plus kingpins etc!!! Really the "Dogs"!!!!! Am on way to Mog13 - will get there later today.
Cheers!
Robbie
211-WX-1433
I had a surprise today. Just driven a Plus4 and a Roadster 3.0 at Williams over a variety of road surfaces and compared to my 4/4 they certainly did not need the Suplex conversion, in particular the Roadster.
Jays #150032 16/08/13 09:32 PM
Jay: your post is most helpful - comfirming what I have been increasingly beginning to suspect - that the benefit of the Suplex kit to my Roadster (which is a 3.0) may be marginal at best. I may as well save my money. Do I read you correctly?
Nick
Jay - must say that my initial thoughts having the Suplex kit on my 2009 Plus4 is that it is a marked improvement. Mainly a lack of "nodding" - no jarring through the steering over potholes - no moving off line over bumps mid-corner. Will post further when I have more Kms driven and when I get back to Irish roads!!
Cheers!
Robbie
211-WX-1433
