0 members (),
354
91
Topics49,860
Posts837,485
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
On my Roadster, most of the allen headed countersunk screws on the hinges are semi-rounded off, and one is a posidrive wood screw...........
Posts: 14,009 |
Sorry Giles...I just couldn't resist! The hinges look great against the black, as i'm sure mine will so in a couple of days time.
Posts: 414 |
Hinges, louvres and screws - one thing is for sure no two Morgans are the same ....
+4 4 Seat Oct 2008 Claret Red
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
Just don't send your wife to buy the hinges
Posts: 414 |
Very true and certainly never to Wickes !
Posts: 4,896 |
This shot shows them off quite well Where can you get them?
Adrian
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Richard 1976 4/4 4 Seater
Posts: 8,015 Likes: 1
Posts: 8,015 Likes: 1 |
I did mine a few years ago they come in a pack if my memory serves me well with polished stainless nuts bolts screw washers etc . I bit of a pig to do but well worth it . Still got all the old stuff in a tub in the garage if anyone wants them.
You needto order the screw (bolt) set separately and the hinges come as a pack of four.
I've just been looking at mine. Upper hinges on both doors use three bolts but the lower hinges only two (seems to have a fake bolt) on the door side of the hinge. Looks like I may need to do some drilling.
Posts: 4,612 Likes: 15
Posts: 4,612 Likes: 15 |
I did mine a few years ago they come in a pack if my memory serves me well with polished stainless nuts bolts screw washers etc . I bit of a pig to do but well worth it . Still got all the old stuff in a tub in the garage if anyone wants them.  I did the same and like JTL says. a bit tricky but worth it. When you remove the old hinges check if there are any slices of material used as a wedge that ensures the door is at the correct angle. I would also recommend getting s/s nuts with nylon inserts to keep the nut tight, you don't want to have to tighten them every year or so.
