3 members (Mats, tezzer, MartinB60), 308 guests, and 79 robots.
Topics49,848
Posts837,408
DazMog, The Impaler, tlchzj79
Page 2 of 5 1 2 3 4 5
Quicksilver #151127 22/08/13 05:20 PM
On my Roadster, most of the allen headed countersunk screws on the hinges are semi-rounded off, and one is a posidrive wood screw...........
DaveW #151159 22/08/13 07:19 PM
Sorry Giles...I just couldn't resist! The hinges look great against the black, as i'm sure mine will so in a couple of days time.
Jays #151161 22/08/13 07:23 PM
Hinges, louvres and screws - one thing is for sure no two Morgans are the same ....
+4 4 Seat Oct 2008 Claret Red
JBu1 #151176 22/08/13 07:55 PM
Just don't send your wife to buy the hinges innocent
Gambalunga #151180 22/08/13 08:01 PM
Very true and certainly never to Wickes !
pandy #151188 22/08/13 08:26 PM
Drive on the Wild Side
Originally Posted By pandy
This shot shows them off quite well
Where can you get them? cheers
Adrian
AJSki2fly #151217 23/08/13 03:21 AM
John Worrel stocks them
Posting Desperado
Posting Desperado
I did mine a few years ago they come in a pack if my memory serves me well with polished stainless nuts bolts screw washers etc . I bit of a pig to do but well worth it . Still got all the old stuff in a tub in the garage if anyone wants them. thumbs
You needto order the screw (bolt) set separately and the hinges come as a pack of four.
I've just been looking at mine. Upper hinges on both doors use three bolts but the lower hinges only two (seems to have a fake bolt) on the door side of the hinge. Looks like I may need to do some drilling.
I did the same and like JTL says. a bit tricky but worth it.
When you remove the old hinges check if there are any slices of material used as a wedge that ensures the door is at the correct angle.
I would also recommend getting s/s nuts with nylon inserts to keep the nut tight, you don't want to have to tighten them every year or so.
