4 members (RichardV6, BLUE+4, TBM, Bilymog), 308 guests, and 35 robots.
+8Rich 89
by stumog - 26/08/26 10:24 AM
Topics49,842
Posts837,332
Christoph
AQM Offline
Originally Posted By donaldosaurus
A wind tunnel experiment is hardly appropriate with the aerodynamic qualities of Cyril Smith in an armchair with someone on his knee!.
Well, cardboard, gaffer tape, and a spirited run on the motorway ought to be enough to test things out before committing, I'd think.
AQM #151872 26/08/13 09:32 AM
AQM Offline
Or what about one inspired by one of these:
Something like that, obviously shaped, and fitted between the "bonnet" and the "nose", and in polycarbonate. I'm guessing that even a narrow one, say 15-20cm, and maybe 3-5cm tall, would make quite a bit of a difference further back in the cockpit.
Originally Posted By planenut
I am not sure at what point a "wind deflector" becomes a windscreen and needs wipers.
In the UK, it's quite simple. An aero-screen or deflector does not need wipers, if you can see the road past it without looking through it. If you have something at the front you do have look through to see where you are going, it's a windscreen and needs washers and wipers.
Thanks for clarifying that Martyn. I am sure you have been through all this with the original 3 wheelers before. I would say that the current "wind deflector" on the M3W (5 speed) is about as large as you could go legally, for hight at least.
Maybe we need smaller drivers?
The Brooklands aeroscreens and the replica Auster ones (and the originals) are adjustable for angle. So as they can lie flat, I'd think that even if normally one had to look though, they'd still not be regarded as a windscreen and need wipers in the UK.
Melvyn Rutter has sold, I think a new car, with Brooklands Aeros fitted and the normal deflectors removed. Looked quite nice from the photo I saw.
