Posts837,252
Posts: 1,213 |
Now the cooler weather has arrived I've reverted to using half the tonneau (when on my own !) Last winter I used it a lot in windy weather and it has stretched quite a bit. I tried soaking it in warm water hoping for some shrinkage as it dried but that didn't work.
I'm now wondering about fixing something to run front to back to support it and help stop the flapping, perhaps a tent pole attached with velcro .Anyone tried anything similar ?
Also now I'm in a getting ready for winter mood , I'd be interested in any reproofing recommendations .
BTW I wonder why they aren't large enough to cover the whole of the leather arm rests , being a bit bigger would probably stop water getting in under the front corner .
Hugh
Posts: 1,647 |
You could always pop over to Creative Covers at the Riverside Estate in Brundall. They could modify what you have to exactly what you are looking for or make you a new tonneau to your spec. http://creative-covers.co.uk/01603 714213 07786007609 They are extremely helpful and tend to be good value for quality work.
Jaguar F-Type V6s roadster 2009 Harley Davidson XR1200 1986 Honda VFR750F (RC24)
Posts: 14,009 |
HJP.....I've used Renevo Hood Proofing in the past. Easy to use and works well. Just keep it off any glass or paintwork!
Posts: 870 |
I'm thinking maybe have a strap of polyester sewn in along the edges, before it stretches, so that you have some resistance to stretch. Or even have it made from some slightly elastic fabric as some (outdoor) motorcycle covers are made from. Although the latter I imagine will be right out expensive.
Posts: 1,213 |
Thanks for your suggestions . I've made a note of Creative Covers details . Having spent £250 on the existing cover I'm a bit loathe to get another made ,but suspect that is probably the answer or maybe modify mine if my own 'improvements' don't work . Perhaps including AQM's ideas to stop stretching . I've seen an ad. for Renovo products somewhere so will get some. Hugh
Hugh
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
I had this problem on a previous car and a local upholsterer sewed in a length of seat belt next to the centre zip front to back. No more problems.
