5 members (Calypso Red, Montegue, Barry M, Mike D, +4competion), 223 guests, and 84 robots.
Topics49,847
Posts837,388
#160532 17/10/13 07:33 PM
Rog Offline OP
Has anybody else found the rear fog and reversing light to be a bit of a nuisance? I’ve had mine taped up with insulation tape for some time now as I feared I might lose them. The issue seems to be the thin metal rolled thread that holds the lens into the rubber mount. The threads have never seemed to engage very well. Tried different fixes without success, ptfe tape, Vaseline on the rubber etc. Could never get them to tightened and align the dummy rivets in either the horizontal or vertical orientation. And if you did manage to get them tight they felt like they would pop back out again at the next pot hole.
So now they have gone. Replaced them with something a little more conventional, courtesy of the Morris Minor parts bin and some new rubber mounts. They were the best combination I could find that were still in keeping with the character of the car, although I know the purest may not agree!
Old & new
Roger
Rog #160534 17/10/13 07:40 PM
Nice mod Roger. Presume one shines red?
DaveW #160535 17/10/13 07:49 PM
Rog Offline OP
Thanks Dave.
Yes I have a red bulb in at the moment. To be honest it’s a bit “pinky” so have ordered the brightest reddest led I could find, and if that doesn’t work it will be a new red glass.
Roger
Rog #160536 17/10/13 08:03 PM
That looks so much better. Are the rubber mounts simply the ones Morgan uses for the front indicators - or something else entirely?
If you could share part numbers etc it would be much appreciated.
Nigel
nputtick #160545 17/10/13 08:35 PM
Rog Offline OP
Hi Nigel
The light units (side/indicators) can be found on this page:
http://www.morrisminorspareparts.com/front-lights
Be sure to ask for the single filament version.
The mounts came from ESM Morris Minors Ltd and are also on
ebay
The bad news is the angle on the back of the mounts needs to be re cut slightly to suit the car. I screwed them to a block of wood and used a chop saw. The hard rubber cuts very cleanly. I think the angle was 25 degs. You also need to drill the holes. The good news is there are no mods to the car.
Roger
Rog #160547 17/10/13 08:51 PM
That looks much much better. Nice work!
Jaguar F-Type V6s roadster
2009 Harley Davidson XR1200
1986 Honda VFR750F (RC24)
Very smart.
Rog #160598 18/10/13 07:15 AM
Drive on the Wild Side
Very nice, looks much better. thumbs
Adrian
You lot, phh! I've got a tarpaulin (blue) on the barn floor.
meabh #160680 18/10/13 03:36 PM
Thanks for the links. The plinths and lights do look great, but the key question is, how bright are they? In particular the rear "fog" lamp needs to be bright, at least as bright as a brake light. I don't think the Morris lamp units used have a very effective reflector. The reverse light is less important.
I'd be interested to see photos especially with the LED red bulb!
Nigel
