2 members (Bunny, Bitsobrits),
324
50
Topics49,843
Posts837,341
Posts: 1,562 |
Hi,
I am half way through adding a plastic trailer mudguard under the boot area of my M3W as described elsewhere in this forum, front end attached fine to the ally stub mudguard - can someone who has done this please described how they secured the back end , I am concerned it could sway about if unsecured ! A picture would be brilliant.
Thanks
Posts: 1,653 |
I think there are pics on another thread. Search mudguard.
I used ally bar bent accordingly. Should have taken pics!
Someone screwed the brackets to the wooden frame but I think right down to the axle is best.
Posts: 1,213 |
I simply screwed through the mudguard into the bottom wooden frame , it's been fine . It took a few goes to get the height right to clear the boot liner , also don't forget the wheel isnt in the middle .
Hugh
Posts: 1,562 |
Cheers chaps , I just wanted some confirmation before I proceeded. I have been taking photos as I went along if anyone is interested.
Posts: 3,643 |
Photos are always welcome
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
Yes photos are always welcome
Posts: 3,560 Likes: 12
Posts: 3,560 Likes: 12 |
I used a flat stainless steel bar across the back, screwed into the wooden frame either side, with one single bolt through the guard. search back through the gallery for my pictures, early last year. It's an easy job, that makes a huge difference to keeping the back clean.
Posts: 1,562 |
First few photos , prior to fitting the new mudguard When you remove the plastic boot floor , you get this view - you can just about spot the small aluminium gaurd the factory fits in front of the tyre ( pathetic ! ) Seeing this you understand why this mod is required ! I had only done about 50 miles from new, and all this compartment was thick with mud etc. Like the pioneers before me, I am goign to fit the new guard using the bolts holding the factory guard on. With the factory guard removed ( two half inch bolts ) , you see this : I have put the bolts back in to show there are two unthreaded holes immediately above the threaded holes - in doing a trial fitting early on I nearly shat myself when I put a bolt into one of these holes accidentaly , thinking the nut was not captive and had disappeared into the box section. No emoticon for that. After a few deep breaths I found the proper holes. distance shot of the same area: The factory guard removed and cleaned up: Is this sort of thing of interest ? I will carry on similarly with fitting the new guard if so. As you might have guessed I have a new camera  Graham
Posts: 1,562 |
thanks Paul , I will do similar though my scrap bin doesnt run to stainless !
