11 members (DaveK, Pyewacket, Tweed19er, david nathan, Graham, G4FUJ, James B W, BobtheTrain, Tresco, teknome, DJC, Bishmog), 433 guests, and 41 robots.
John V6 68
DaveW 64
+8Rich 62
9,208 Registered Users
by Soleng - 24/07/25 05:32 PM
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
Topics48,347
Posts813,071
Captain Morgan, IRWIN
Double sided automotive trim tape, about 1 inch wide, works for my California plate (made of aluminum). Make sure to clean all surfaces with a degreaser. I used to 5 inch strips and it is very secure, even on our 90 degree summer days.
http://solutions.3m.com/wps/portal/3M/en...3beK4JN83P3JZgl
le Asbo du Bling
le Asbo du Bling
Originally Posted By Matty
Do we not need one by law?
From the bits I've rad hear and elsewhere it would appear that the number plate is only needed for MOT and for no other reason.
I relocated mine some time ago, as it was grounding out on speed bumps and then eventually fell off, honestly officer. Strangely though it seemed to change colour when this happened.
Slowly going green
Cracking looking car John...
I run without a front plate and a black and silver motorcycle sized rear, plod has had a good look and I've been followed a few times but never pulled.
DVLA guidance "motor cycles and motor tricycles registered after 2001 do not need to display a front numberplate'.
I have printed this off and carry it with me.
The UK reflective plates do help with you being seen
Tim
I think this has come up before. I don't like front number plates - faffy things that as Asbo Jon says get in the way. The Road Vehicles (Display of Registration Marks) Regulations 2001 are the relevant Govt bumf. Part II Section 6 (5)says:
"In the case of a motor cycle or a motor tricycle which does not have a body of a type which is characteristic of the body of a four-wheeled vehicle—
(a) a registration plate must not be fixed on the front of a vehicle if it was first registered
on or after 1st September 2001,
(b) a plate need not be fixed on the front of the vehicle if it was first registered before 1st
September 2001."
So no front plate allowed for a M3W five speeder. Depending on how you interpret the 'body of a type' clause. And a pre-2001 M3W can take its pick.
www.legislation.gov.uk/uksi/2001/561/pdfs/uksi_20010561_en.pdf
smile
Notlob
There is no doubt IMHO that the M3W looks better without a front plate - and u do not need one!! I bought a "MOG" plate and love seeing it "up front" BUT when this delight fades I intend to follow ASBOs lead and buy a B/W classic metal version for the rear only. laugh2
They are illegal - but I hear that u are v v v unlikely to get "done" for having them on! scared
Unless u know differently??? innocent
BTW love the look of yr car ASBO - not just because mine is also Black!!
Neil
