8 members (Alan Patterson, piquet, +8Rich, Paul F, MartinB60, Luddite, stumog, Strathaven),
237
83
Topics49,866
Posts837,592
Posts: 287 Likes: 1
Posts: 287 Likes: 1 |
I know this has been discussed a number of times but I have one more (hopefully the last) question. I now have a 12v buzzer with two cable terminals, and I have the wiring diagram for the dashboard cabling. What I've found is that there are separate feeds for the left and right indicator lights on the dash, and since the buzzer does not earth through its body, I seem to be faced with a 2-terminal buzzer I need to connect to 3 cables. Unless I'm missing something. Any helpful suggestions? (Also, should I use an in-line fuse on the live side of the buzzer?)
Roger South Wales 2003 4/4 (Meg) Connaught Green
Posts: 287 Likes: 1
I think it might. My problem may be that the wiring diagram I have doesn't trace back as far as the flasher unit. If I can locate that it might work as you suggest.
Posts: 389 |
If you connect the live side of the buzzer two both signal lamps on the Dashboard it could be useful to intigrate diodes.
BR
Christian
2006 4/4 70th anniversary, 1985 VW 1200 50th anniversary, 1977 Vespa 50 Special, 2003 Vespa PX 200E
Posts: 167 |
You can connect to both indicator lights, but you need a diode in both the lines to prevent them cross talking.
'65 +4 four seater
Posts: 287 Likes: 1
You can connect to both indicator lights, but you need a diode in both the lines to prevent them cross talking. Good idea. Can you suggest a source for the diodes?
Posts: 1,947 |
Maplin If the audible alarm is a pietzo sounder, a 1 amp diode will be plenty. All of 49p. 1 amp diode Added - but not really needed if you wire the sounder to the flasher unit.
Posts: 1,616 Likes: 1
Posts: 1,616 Likes: 1 |
Whole kit with buzzer, diodes and instructions available from car builder solutions for £6. Kit INDBUZ www.cbsonline.co.uk
John 1992 plus4 connaught green
Posts: 287 Likes: 1
Thanks, guys. All good stuff. I think I know what I need to know, now.
