1 members (+8Rich), 328 guests, and 37 robots.
John V6 69
+8Rich 66
DaveW 66
9,208 Registered Users
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Topics48,345
Posts813,036
Captain Morgan, IRWIN
#169396 05/12/13 06:46 PM
RogerS Offline OP
I know this has been discussed a number of times but I have one more (hopefully the last) question.
I now have a 12v buzzer with two cable terminals, and I have the wiring diagram for the dashboard cabling. What I've found is that there are separate feeds for the left and right indicator lights on the dash, and since the buzzer does not earth through its body, I seem to be faced with a 2-terminal buzzer I need to connect to 3 cables. Unless I'm missing something. Any helpful suggestions? (Also, should I use an in-line fuse on the live side of the buzzer?)
Roger
South Wales
2003 4/4 (Meg)
Connaught Green
Roger, I'm also hoping to fit a buzzer. It would seem that the wires are fitted direct to the flasher unit.
Does this make sense?
http://www.mgb-register.org/MGB-Register/Tech_Audible_Warning.html
2015 Plus 4 (GDI) Sport Green
RogerS Offline OP
I think it might. My problem may be that the wiring diagram I have doesn't trace back as far as the flasher unit. If I can locate that it might work as you suggest.
Roger
South Wales
2003 4/4 (Meg)
Connaught Green
If you connect the live side of the buzzer two both signal lamps on the Dashboard it could be useful to intigrate diodes.
BR
Christian
2006 4/4 70th anniversary, 1985 VW 1200 50th anniversary, 1977 Vespa 50 Special, 2003 Vespa PX 200E
You can connect to both indicator lights, but you need a diode in both the lines to prevent them cross talking.
'65 +4 four seater
RogerS Offline OP
Good idea. Can you suggest a source for the diodes?
Roger
South Wales
2003 4/4 (Meg)
Connaught Green
Maplin
If the audible alarm is a pietzo sounder, a 1 amp diode will be plenty. All of 49p.
1 amp diode
Added - but not really needed if you wire the sounder to the flasher unit.
Whole kit with buzzer, diodes and instructions available from car builder solutions for £6. Kit INDBUZ www.cbsonline.co.uk
1992 plus4 connaught green
RogerS Offline OP
Thanks, guys. All good stuff. I think I know what I need to know, now.
Roger
South Wales
2003 4/4 (Meg)
Connaught Green
