1 members (ChrisConvertible),
212
32
Topics49,841
Posts837,323
Posts: 262 |
Does anyone know what the total coolant capacity is of the Aeromax? It's not mentioned in the Owner's Handbook.
Posts: 262 |
Hi Ale_72. You're right - I must have missed it: it is on Page 4 of the Aeromax handbook and it's also 11 litres (2.9 US Gallons). Mechanically, the Max should be identical to the Aero 8 MkIV, Super Sports and Coupe - and I suppose even the new +8 too. What gets me though is that the coolant capacity is very small for a 4.8-litre engine. Compare that with a diminutive Suzuki Cappuccino (engine displacement 658cc) with a coolant capacity of 4.0 litres (8.5 US pints) and a Ferrari 412i with a 5-litre V12. The latter's coolant capacity is 18 litres (4 Gallons)! Cheers!
Posts: 1,508 Likes: 57
Posts: 1,508 Likes: 57 |
The winner is still the 997 I had before with 31.5 liters of coolant for a 3.8 liters engine.
Posts: 262 |
That (997) sure take a lot of beating...  I'm sure the 4.8-litre V8 BMW engine gives off just as much heat as the Ferrari and the 997 and hence their large coolant capacities. But I guess the factory knows what they're doing when they gave that small [coolant] figure...  BTW, I drove across the Nullarbor on my way back to Perth a few months ago and noted that the water temperature gauge was reading uncomfortably high - in fact, a little more than 3/4 of the way up! Usually, it would read Normal even on a long run. So in that respect, I would have thought that a larger coolant capacity could be the answer. However, as it's nearing the time for a system flush and new coolant, I thought I would try a product called Evans Waterless Coolant. From what I've read, it looks like the solution to my query - to keep the temperature gauge from climbing too high even on a long run!
Mine is usually staying in this range.  Only once I had to top up the coolant (since I got the light on in the dash). From that moment on I am keeping it under control but I never had any further level drop. The same happened to me with the 997 after the first or the second time I took it into the garage (underground with a step ramp). I guess that in both cases there was some air in the circuit.
Posts: 262 |
Thnx for the tip! I'll check for air pockets when filling with fresh coolant. (Hadn't crossed my mind to check for air in the system...) Cheers!
Posts: 11,524 Likes: 312
Posts: 11,524 Likes: 312 |
Don't forget the 911 has the engine at the wrong end and the rad at the front 8^) and so it needs to fill the pipes.
Ale, my coupe sits between 97 and 105' it does not go as high as yours. Having said that I do not have the air con on and it has not been as hot since I have had the coupe. We should chat re the other fun findings.
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Chris: the research of done on Evan's waterless coolant is mixed. The flushing of the system to remove all water has put me off. Although there's a supplier in Perth.
Richard 1976 4/4 4 Seater
Posts: 262 |
Hi Richard. It can't do any worse than the standard ethylene glycol I have in the car! So I'm giving that waterless fluid a go.
I have already installed this product in one of my other cars which I'm taking for a field test this Sunday morning (the 22nd). This car also exhibited the same problem (temperature running higher than usual) as the Max.
