Morgan Aero 8
5 members (+8Rich, RichardV6, nick w, BLUE+4, Morganmike), 259 guests, and 52 robots.
+8Rich 89
by stumog - 26/08/26 10:24 AM
Topics49,842
Posts837,332
Christoph
Page 2 of 4 1 2 3 4
Mad Max #171772 20/12/13 05:56 AM
Sounds good - I'm fitting an air scoop this weekend to help with the WA summer!
Mad Max #171780 20/12/13 07:27 AM
Mad Max Offline OP
Hi Richard. I'll be reporting back on this thread with the results of the waterless coolant. And if it lives up to expectation, I will replace the glycol in the Max with this new substance. smile
cheers
Mad Max #171789 20/12/13 08:48 AM
I'm sure they're many on hear who will be interested to hear the results.
Mad Max #171793 20/12/13 09:19 AM
Mad Max Offline OP
OK. Watch this space... smile
Mad Max #171935 21/12/13 07:17 AM
Mr Fezza
Mr Fezza
Remember folks that this is a hand finished car, so comparisons on exact temps between cars from the onboard temp gauge may not be comparing apples with apples.
If the range of movement of the gauge is similar that probably tells us more than if the indicated temp is 105 or 120.
My s4 ran an indicated 90-120, the Aeromax runs 80-110. I suspect that in reality both are within a degree of each other and the instrument calibration is the difference...
Maxxed out!
Mad Max #171975 21/12/13 11:04 AM
Smile, it confuses them
A bit like the petrol gauge then. Should be a little symbol saying "any information given on the availability of petrol is intended for guidance and may go up or down in the future" blush
Mad Max #172049 21/12/13 06:52 PM
No, really... Is somebody relying on those fancy gauges behind the steering wheel?
I thought they were just nice decorative things to make nicer the aluminium dash.
Mine are saying:
- Some gas in it (maybe)
- Floor pedal when possible
- Engine running or not
- Engine cold/hot
Mad Max Offline OP
I've got the trial results back this afternoon and the results are outstanding! happy3
The test car was driven through the city (stop-start) as well as a spirited drive along windy country lanes; and the needle stayed steadily on the Normal mark! Not once did the needle go past it! (It did with glycol...)
I will now be changing the coolant [in the Max] to the waterless variety early next year! smile
cheers
mr_tony #172110 22/12/13 06:02 AM
Mad Max Offline OP
The gauges and sensors are mass-produced items unlike body panels and interiors, so readings supplied by those components should be pretty well uniform across the model range. the small discrepancy you mentioned should be just that - small! I think though that as the Aero8 S4 and Max are mechanically identical, this minute difference (+/-1) can be "safely" ignored...
Alistair #172111 22/12/13 06:06 AM
Mad Max Offline OP
Ah yes, the petrol gauge! It's very much a "hit-and-miss" thing with owners! Surely someone must have thought of a way of putting that right by now??? confused2
Page 2 of 4 1 2 3 4
