6 members (+4competion, Mike D, Barry M, jbk, Mogdavid, AndyGoff), 221 guests, and 82 robots.
Topics49,847
Posts837,387
Page 3 of 7 1 2 3 4 5 6 7
TimG #174799 07/01/14 07:48 PM
PeterG Offline OP
Originally Posted By TimG
I'm about to Dynamat behind & under the seats on my M3W. Behind the lower backrest on the bulkhead there is what appears to be sound proofing. Was it present on your car & if so did you remove it before you did the job? Did you silicone seal any gaps beforehand?
Tim
Hi Tim
Is it black like in this picture?
If so no I left it on. I didn't silicon the gaps, I overlapped / filled them with the off cuts. I did seal the rear square section that you can see the seatbelts from the boot and also the prop tunnel section.
PeterG #174836 07/01/14 11:11 PM
SBM Offline
Where is the best point to leave a drain hole? forward of the crossmember or under the seats?
PeterG #174870 08/01/14 11:22 AM
Peter, yes its the black stuff I'm asking about. OK I'll leave it on. I don't intend initially to remove transmission tunnel.
Tim
SBM #174875 08/01/14 12:02 PM
I have been wondering about putting in drain holes in strategic places , but then thought they equally could become even more filling up points so have backed off to date.
Any one got any bright ideas about letting water out as you drive along ? gloomy NOT sick
( I have re written that sentence 5 times now and cant improve on the double entendre quiet )
PeterG #174877 08/01/14 12:14 PM
I would have thought that a small flap of rubber partially glued to the underside, covering the hole would act as a good 1 way valve?
PeterG #174885 08/01/14 01:00 PM
A neoprene flap valve then............
MGB's had holes in the floors and underneath were rear facing metal U shaped covers.
PeterG #174895 08/01/14 01:41 PM
Or do as one 4 wheeler does, fit bath plugs into his floor panels!
Jays #174905 08/01/14 02:22 PM
Or; the screw in hot water bottle stopper, as fitted to the Lotus VI we saw parked in the ferry queue at Portsmouth?
Bud
4/4 "Stanley"
PeterG #174957 08/01/14 05:44 PM
Ha - with a bath plug size hole I might be able to let out some water as I drive along ! thinking
PeterG #174964 08/01/14 06:17 PM
Dave Sapp has the bath(room) plugs in the floors.
