8 members (bmgermany, RedThree, mph, cerealsurfer, Gordon D, TalkMorgan, John Winn, TBM),
216
88
Topics49,847
Posts837,389
Posts: 1,959 Likes: 15
Posts: 1,959 Likes: 15 |
Peter I'm about to Dynamat behind & under the seats on my M3W. Behind the lower backrest on the bulkhead there is what appears to be sound proofing. Was it present on your car & if so did you remove it before you did the job? Did you silicone seal any gaps beforehand?
Tim Hi Tim Is it black like in this picture?  If so no I left it on. I didn't silicon the gaps, I overlapped / filled them with the off cuts. I did seal the rear square section that you can see the seatbelts from the boot and also the prop tunnel section.
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
Where is the best point to leave a drain hole? forward of the crossmember or under the seats?
Posts: 1,947 |
Peter, yes its the black stuff I'm asking about. OK I'll leave it on. I don't intend initially to remove transmission tunnel.
Tim
Posts: 1,562 |
I have been wondering about putting in drain holes in strategic places , but then thought they equally could become even more filling up points so have backed off to date. Any one got any bright ideas about letting water out as you drive along ?  NOT ( I have re written that sentence 5 times now and cant improve on the double entendre  )
Posts: 3,560 Likes: 12
Posts: 3,560 Likes: 12 |
I would have thought that a small flap of rubber partially glued to the underside, covering the hole would act as a good 1 way valve?
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
A neoprene flap valve then............ MGB's had holes in the floors and underneath were rear facing metal U shaped covers.
Posts: 14,009 |
Or do as one 4 wheeler does, fit bath plugs into his floor panels!
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
Or do as one 4 wheeler does, fit bath plugs into his floor panels! Or; the screw in hot water bottle stopper, as fitted to the Lotus VI we saw parked in the ferry queue at Portsmouth?
Bud 4/4 "Stanley"
Posts: 1,562 |
Ha - with a bath plug size hole I might be able to let out some water as I drive along !
Dave Sapp has the bath(room) plugs in the floors.
