Morgan Aero 8
4 members (GrumpyPa, Morganmike, bmgermany, Ian Wegg), 295 guests, and 94 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
Page 8 of 8 1 2 3 4 5 6 7 8
I'll take a look tonight Peter...
Your camera can go to higher resolutions than the one I have returned.
Wondering whether to take another look at the Polaroid mentioned in another thread some months ago...
Mad Max Offline OP
There is actually a higher resolution available but it takes too long to load more than a few minutes on YouTube and uses more memory. I have it set to 1280 x 720 at the moment but it has lower and higher resolutions available. The higher resolutions are 1440 x 1080 and 1920 x 1080. I have noticed that YouTube also seems to "adjust" the resolution in some way and that videos uploaded often seem to have a lower resolution than the original.
Hi Peter
Agreed. The higher resolutions do take a little longer to load because the processor isn't fast enough; which is why with the H.264 encoding, it's the best option for the current technology available. The J-MPEG is the previous generation, but it also takes up plenty of memory: in fact, more than the H.264!
This of course means that if there is a 5 hour recording time with the H.264 using a 32GB card, it's under 4 with the J-MPEG.... and that's a lot! Higher resolution systems will mean less still!
But SD cards are cheap(er) these days so changing them each time you have to stop to fill up is not a great hardship (and can be reused/downloaded to a harddrive)......
Mad Max Offline OP
The info I gave wasn't mine, I'm afraid. In fact, it came from Techmoan, the guy on YouTube; and whose reviews on dash cams are both informative and entertaining. laugh
120 degrees is good Peter. Nice road smile I found 160 just too wide. Will keep looking!
Mad Max Offline OP
120 degrees is good Peter..... I found 160 just too wide.
+1
Smile, it confuses them
Just for those looking for a cheap one - eBuyer have a deal going today only (Saturday for those watching this on download or repeat laugh )
http://www.ebuyer.com/710095-720p-hd-in-car-journey-recorder-with-free-8gb-sd-card-zv002
£15
I have not used or seen it but at £15 it has to be worth a go ?
Hope its okay if you do try it. eBuyer have traditionally done a good job of returns.
I bought this more than one year ago and I am really pleased with the results laugh2
Camera (be careful not to buy one of the thousands fake)
http://www.amazon.it/QUMOX-SJ4000-Silver-Waterproof-Helmetcam/dp/B00HHRFHG6
How to spot fakes (there are tons of sites)
https://www.wearechampionmag.com/how-tell-difference-between-sjcam-4000-original-and-fake
Video (toggle HD on)
https://www.facebook.com/MorganAeroSS/videos/318761688309394/
