Topics49,847
Posts837,389
Posts: 28,894 Likes: 351
Posts: 28,894 Likes: 351 |
I'll take a look tonight Peter... Your camera can go to higher resolutions than the one I have returned. Wondering whether to take another look at the Polaroid mentioned in another thread some months ago...
Posts: 262 |
There is actually a higher resolution available but it takes too long to load more than a few minutes on YouTube and uses more memory. I have it set to 1280 x 720 at the moment but it has lower and higher resolutions available. The higher resolutions are 1440 x 1080 and 1920 x 1080. I have noticed that YouTube also seems to "adjust" the resolution in some way and that videos uploaded often seem to have a lower resolution than the original. Hi Peter Agreed. The higher resolutions do take a little longer to load because the processor isn't fast enough; which is why with the H.264 encoding, it's the best option for the current technology available. The J-MPEG is the previous generation, but it also takes up plenty of memory: in fact, more than the H.264! This of course means that if there is a 5 hour recording time with the H.264 using a 32GB card, it's under 4 with the J-MPEG.... and that's a lot! Higher resolution systems will mean less still!
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
But SD cards are cheap(er) these days so changing them each time you have to stop to fill up is not a great hardship (and can be reused/downloaded to a harddrive)......
Richard 1976 4/4 4 Seater
Posts: 262 |
But SD cards are cheap(er) these days so changing them each time you have to stop to fill up is not a great hardship (and can be reused/downloaded to a harddrive)...... The info I gave wasn't mine, I'm afraid. In fact, it came from Techmoan, the guy on YouTube; and whose reviews on dash cams are both informative and entertaining.
120 degrees is good Peter. Nice road  I found 160 just too wide. Will keep looking!
Posts: 262 |
120 degrees is good Peter..... I found 160 just too wide. +1
Posts: 11,526 Likes: 312
Posts: 11,526 Likes: 312 |
Just for those looking for a cheap one - eBuyer have a deal going today only (Saturday for those watching this on download or repeat  ) http://www.ebuyer.com/710095-720p-hd-in-car-journey-recorder-with-free-8gb-sd-card-zv002 £15 I have not used or seen it but at £15 it has to be worth a go ? Hope its okay if you do try it. eBuyer have traditionally done a good job of returns.
Posts: 1,508 Likes: 57
Posts: 1,508 Likes: 57 |
