Topics49,847
Posts837,388
Posts: 368 Likes: 1
Posts: 368 Likes: 1 |
I want to add another positive vote for the 280mm VDO fuel sender. I put mine in this morning in a relaxed half hour. The gauge was showing 66% with the 220mm unit and then showed 80% after installation of the 280mm unit. Good upgrade!
Posts: 19 |
See you are in Mesa. I am up in Carefree. If you drive(ride) North stop by.
Tom BRGMog
Posts: 1,653 |
Posts: 1,213 |
I wonder when/if the factory will start fitting them ? Perhaps when they've used up existing stock .....
Hugh
Posts: 1,653 |
HJP you may be right but they are learning in so many ways
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
Surely they should be on J.I.T. and not stockpiling tank senders.
Posts: 368 Likes: 1
Hi Tom,
Next time we run up to Pine for ice cream, I will let you know.
Roland
Posts: 1,948 |
Surely they should be on J.I.T. and not stockpiling tank senders. Suppliers might not be willing to do JIT for the small volumes that MMC operate to. Elsewhere there is a current thread that gives 2014 M3W production as 300 a year/25 a month/roughly 1 per working day, so it would only be economic for suppliers to do batch deliveries.
Stuart "There's no skill substitute like cubic inches."
Posts: 1,653 |
Wow those Eurospares are fast, under 24 hours and delivered on a Saturday. A nice little job for a wet and wild day today.
Posts: 6 |
Presume you disconnected your battery before fitting the sender? Was there any electronic memory loss?
