2 members (waikiore, linklaw), 520 guests, and 40 robots.
+8Rich 69
Adam12 69
John V6 52
9,215 Registered Users
Folding Reclining Seat Knob
Goodwood Speedmog 2d august
by Nick55 - 01/08/25 09:09 PM
Walnut Dashboard
by +8Rich - 01/08/25 06:24 PM
SORN
New
Morgan plus Four 2025
by Jérôme, August 2
Pedal mod
Pedal mod
by RibbleAdventures, July 31
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
Topics48,375
Posts813,541
Members9,215
Page 5 of 6 1 2 3 4 5 6
^ I like it. I picked up a few 'snap rings', stronger that the 'circ rings' supplied. With springs and grommets, should snug nicely ! thumbs cheers
Oh and I'll see your Glenfarclas and Clynelish (both favorites) and raise you one Talisker ! Why enjoy one ... cheers thumbs
2013 M3W # 793
'Mosquito'
+1
Peter Dron kindly gave me this link so I ordered mine.
http://www.completeautomobilist.com/products/148-bonnet-catch-small-chrome
Still unsure how to blank the original Dzeus holes.
Toys for Boys
Toys for Boys
Now 'out of stock' and they don't have a delivery date frown
Omne trium perfectum
I have bought a set of these clips and am ready to start this job.
However on checking the clearance inside the body where the holes will appear, i.e. inside the cockpit , I can see a section of the wood body frame running along under this section presumably as support blocking access to this area.
Question for anyone who has already fitted these - did you screw down into this wood or find a way to get nuts onto the bolts holding the clips ?
I know space is tight down there but a picture from about where your knees are in normal driving position towards the fitting from the inside would be most appreciated ( or a drawing ! )
TTC Offline
OXR 5
OXR 5
Toys for Boys
Toys for Boys
TTC - thanks smile Useful site!
Make sure you mount the base of the forward clips outside the ash frame, otherwise the rubber pads will not press upon the cowl, which is essential.
I cannot comment on the rearward section, except to say that it is evident that drilling into the wood will be necessary. I kept the rearward Dzus fasteners, because they work correctly.
If you check back through this thread to 10/01/14 06:36 AM, you will find a blurry photo of mine that Raphael kindly posted for me (I had problems uploading photos at that time - and do not have time at the moment to post that photo again), which will give a rough idea of where to drill.
This is really a two-man job unless you are a smallish acrobat. I have long, simian arms but did my back a mischief trying to do the job solo.
Also, I repeat this important advice:
At the risk of stating the obvious to those with greater skills than I have in these matters (ie quite a lot of people on here), the technique when drilling into fragile materials such as tiles, glass or, as in this case, painted metal, is as follows:
1) Cover the target area with masking tape.
2) Carefully mark the drilling point with a pencil.
3) Start with a smaller drill bit than the hole you will finally make.
4) Set the drill to its lowest speed (and check that the hammer option is off!).
5) Proceed carefully.
6) Enlarge hole to final size.
7) Remove masking tape.
8) Finish job.
9) Have a glass of Aberlour.
I like the ninth step!!! cheers
Neil
Hi Peter
I have lifted this picture from earlier in the thread - I think it is yours and the one you refer to ?
If so , is the clip at this position inside of the wood frame or on the outside of it ?
Thanks
