0 members (),
431
43
Posts837,277
Posts: 1,597 |
My friend has a 1996 4/4 with the 1800 Zetec and is having problems with the engine. It starts and runs, but badly. Engine surges and dies and occasionally misses. He has changed the leads and plugs etc, but no change and now would like to get it diagnostic tested. The connection on the car is the old 3 pin diagnostic head but has not been able to find a garage with this connection. The car is in Northern Ireland so not handy to a dealer, are these diagnostic connectors available on the mainland. The Connaught green car waiting for the Strangford Ferry is the very beauty.  Any help gratefully received Dave
Posts: 2,431 Likes: 17
Posts: 2,431 Likes: 17 |
Connectors should be freely available on the likes of eBay I would have thought? Have you tried your local Ford dealer assuming it's a Ford item but knowing Morgan ............. Worth a call to the factory maybe ?
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 28,888 Likes: 350
Posts: 28,888 Likes: 350 |
I bought one of these: http://www.amazon.co.uk/gp/product/B002WHDZCO/ref=oh_details_o05_s00_i00?ie=UTF8&psc=1a Gunson 77032 fault code reader for my early ('93) Silvertop Zetec. Has both 3 and 5 pin Ford connectors...
Posts: 1,597 |
Graham and Taff, Many thanks for your replies, I will pass on your thoughts Dave
Posts: 1,597 |
Graham, We are very interested in that Gunson Code reader but can't tell from the pictures if the connector is round in shape and has a triangle bit in the middle. Have you a picture of your one. Dave
Sorry, no photo. The 3 pin connector is triangular with a rectangle below the triangle. The '5' pin connector contains only 3 pins, the body is more oval with a flat base - two pins in the base area, one at the rounded top, with two holes in the middle area for extra pins. Both connector types are on my car too, so I could connect to either...
Posts: 491 Likes: 6
Posts: 491 Likes: 6 |
Hi I had a very similar problem with a 2004 zetec 4/4 , misfire ,engine stalling, had it checked at a ford dealership but nothing showed on the diagnostics as it was an intermitant problem,it turned out to be a faulty fuel pump relay!
2015 +4 and 2000 4\4 1981 Lambretta GP225 1960 Lambretta LI 125
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
Hi I had a very similar problem with a 2004 zetec 4/4 , misfire ,engine stalling, had it checked at a ford dealership but nothing showed on the diagnostics as it was an intermitant problem,it turned out to be a faulty fuel pump relay! That is a good call. I always now carry a spare relay which can be used either for the fuel pump, or the cooling fan; having had one fail in the past. Also, very easy to check.
Bud 4/4 "Stanley"
Posts: 3,383 Likes: 14
Posts: 3,383 Likes: 14 |
Have a look for signs of burning around the coil pack towers (where the HT leads connect) another well known Ford weak point. Copy parts available on eBay and I know of 3 cars who have used these cheaper replacements for years. Ford altered the spark plug gap as high mileage and wide plug gaps increase coil output KV's and this overheats the coil pack leading to failur.
Posts: 1,511 Likes: 21
Posts: 1,511 Likes: 21 |
Hi, i have a zetec in my 1991 4/4. The fuel pump is next to petrol tank. I had similar problem found a loose connection. Might just be as simple as that.
