1 members (+8Rich),
289
50
Topics49,860
Posts837,486
Posts: 970 Likes: 1
Posts: 970 Likes: 1 |
Magwa 1950 Allis Chalmers B tractor 2000 Porsche boxster 2014 Skoda yeti 4x4 elegans
OXR 5 L - Learner Plates On
Posts: 209 |
Posts: 2,780 Likes: 5
Posts: 2,780 Likes: 5 |
Thanks for your kind comments, yes i'm pleased with it so far, have to cut another hole in it yet for the clock and then I think its ready for wiring up and fitting up with my existing gauges etc.
Total costs I reckon will be £100 - £150 (including the dash panel, lights, switches and laser cutting etc) so not so bad..
Another thought, while I have the dash in bits ought I change the gauge bulbs to LED's ?
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Another thought, while I have the dash in bits ought I change the gauge bulbs to LED's ? Given the lack of illumination from the bulbs probably worth a try...I wonder if the "dimmer" would work and better, or worse or at all. I know some LEDs are dimmable and others are not, but don't kow wht.
I might not bother with the dimmer... Always on 'max' anyway!
So 'new' dash is in. A few tricky bits sorting out the change from rocker to flip switches and the first led warning lamps were rubbish so had to upgrade to some better but bigger ones. A small fire, but otherwise all in and working!
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
A big improvement - that looks like the dash format which lasted until 2006.Very nice job!
Posts: 5,654 Likes: 4
Posts: 5,654 Likes: 4 |
A big improvement - that looks like the dash format which lasted until 2006.Very nice job! +1 looks the business
Martin (Deano)
A big improvement - that looks like the dash format which lasted until 2006.Very nice job! Agree 100% with DW! What is the big red switch on the right, master ignition cut out?
