2 members (Tom Sayles, 1560),
365
80
Topics49,880
Posts837,757
Posts: 287 Likes: 1
Posts: 287 Likes: 1 |
Hi, all. I need some help with a wiring problem (2003 4/4). A recent loss of all sidelights showed that all my sidelights, front fogs, number plate lights and cigar lighter work off the same fuse. Since I'm about to add a map light to the unused feed from the cigar lighter I'm concerned about overloading the fuse. I thought a good solution would be to separate the cigar lighter (and map light) onto a fuse of their own. Do any of you have any experience/advice of such a job? Any help would be most gratefully received. Thanks.
Roger South Wales 2003 4/4 (Meg) Connaught Green
Posts: 517 |
The cigar lighter is usually rated at 10amp as it is a heavy load. Your map light would not be anything like that and if it is an LED it would be in micro amps. You could run a separate fuse but the existing fuse would be fine. Titus
Titus
2007 +4 4 seater 2017 Mini Cooper 2007 VW Camper 1996 Honda TRX300 2012 Husqvarna 216
Posts: 287 Likes: 1
Thanks, Titus. I know there's an led option for the map light, so perhaps I'll take that route.
Posts: 28,906 Likes: 353
Posts: 28,906 Likes: 353 |
Good idea to move the cigar lighter (oh, err, accessory socket  ) to a separate fused supply anyway Roger.
Posts: 287 Likes: 1
Seems like an interesting challenge since the gomog-supplied wiring diagram doesn't quite match the reality of my car - only to be expected, I suppose.
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
The unused lead from the cigarette lighter is used by Morgan when they install the optional map light.
Posts: 287 Likes: 1
Fitted my Holden chrome map light yesterday using that feed. Still might isolate that circuit onto its own fuse.
